Question about HP DeskJet 5550 InkJet Printer
HP 5550 will not print test page
"Removed" printer icon from printer list, totally unplugged printer (power and USB cable), restarted computer, plugged in usb cable. Computer immediately detected the printer and loaded the correct software from Windows Vista. HP 5550 printer icon appeared but does not show "ready" under the icon. Right click on icon shows status as "Ready". Does not print test page. Help!
jaylex
  • 417 Answers
SOURCE: Printer will not print
Hi Check that the cable is fully into the printer also make sure that there are not any lights on the printer that are on. Within the printer icon right hand click on it and select properties. Once in there select the ports tab at the top of the window and check that the port that is selected is the correct one i.e. LPT1 or USB or which ever the printer is connected to.
Once you have check these try clearing the print que and print a test page from the properties window. If the printer prints ok then there is nothing wrong with the printer and make sure that within the program that you are using the correct printer if not change to the correct one by Ctrl: P and then at the top of the window it should state what printer is to be used.
Hope this works for you
Thanks J
Posted on Jan 12, 2008
  • 102 Answers
SOURCE: My Hp2015 Driver cant install in winxp
Try universal printer drivers and i m sure it will work.
Try to download and install the drivers from the link mentioned below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1845551&prodNameId=1845552&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ja-45284-9
Posted on Jul 03, 2009
  • 39 Answers
SOURCE: HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Posted on Feb 17, 2010
MSG-CPC
  • 1325 Answers
SOURCE: I have an HP Deskjet 5150 that will not print.
hello
i have this link for you
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02205477&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=304431
If it does not help you resolve the issue, i strongly suggest contacting HP support
God's speed :)
Posted on Nov 09, 2010
puertobori
  • 7733 Answers
SOURCE: Hi. I just replaced the
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 28, 2010
Wont Print no icon on the control panel or device and printer page down load to print test page Les
Browse below link, select OS, download full feature drivers.. save it..Installation procedure: Un plug USB cable, un install loaded drivers through control panel. Restart the system run the drivers, connect the USB cable when its appears on screen run rest of the drivers.. once installed check for icon in printer drivers.. print test page & confirm for the print as well as check for the scan...Link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3418707&lc=en&cc=us&dlc=en&lang=en&cc=us
Dec 30, 2011 | HP Photosmart C4580 All-in-One InkJet...
HP Officejet 5610 will not print from an application or run a test print. Returns "...Operation could not be completed (error 0x0000007a)." on test print funtion from Windows Control Panel.
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 11, 2010 | HP Officejet 5610 All-In-One InkJet...
Hp Printer 5650 Printing Failure My system: Mac 7300 upgraded with MaxPower G3, and a PCL USB & Firewire card. An alternate system tried was a Wallstreet G3 laptop with a USB card. Both systems were...
Print failure is a very common issue faced by users while printing a document. There could be many issues if you are unable to print from HP printer. But you don't need to worry, we are here to help you out.http://www.hptechsupportnumber.com/ HP Tech Support Phone Number 1 877 645 7494 HP Helpline
Feb 28, 2017 | HP DeskJet 5650 InkJet Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
Hp deskjet 3650 printer works very slowly with win 7
tion one: Check the power supply Follow these steps to check the power supply to make sure that it is functioning correctly.
  1. Turn the product so that you can access the rear side.
  2. Unplug the power cord from the back of the product. Figure 1: Unplug the power cord from the back of the product
  3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
  4. Plug the power cord directly into a wall outlet.
  5. Print and time a self-test again.
  • If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet.
  • If the test page takes significantly longer than 30 seconds to print, continue to the next solution in this document.
Solution two: Check the USB connection
  1. Disconnect the USB cable from the back of the HP product. Figure 2: Disconnect the USB cable from the back of the HP product
  2. Disconnect the USB cable from the back of the computer.
  3. Wait five seconds.
  4. Reconnect the USB cable to the back of the product and the computer, according to the following guidelines: The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Connect the small end of the USB cable to the back of the product Connect the other end of the USB cable to the computer
  5. After you make sure that the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
    • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
    • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high-quality. Otherwise, HP recommends using a USB cable that is less than 2 m (6 feet, 6 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
    • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the problem.
    • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
    • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
  6. After checking the USB connection, print and time a self-test page again.
  • If the test page prints in 30 seconds or less , the problem relates to the USB connection. Replace the USB cable or modify the connection to meet the preceding criteria.
Solution three: Check cartridge compatibility Incompatible cartridges can cause the slow printing problem. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge in a language other than English, click the language link near the globe icon (c01906983.gif ) in the upper right corner of your browser. Examine the cartridges in your HP product, and then follow these steps to check which cartridges are compatible with your product. The number on the cartridge label must match the numbers listed on HP SureSupply.
  • If the cartridges are not compatible with your HP product , replace the cartridges. You can order replacement cartridges directly from HP SureSupply.
  • If the cartridges are compatible with your HP product , continue to the next solution in this document.
Solution four: Perform a reset A reset drains the power from the product and returns it to the same settings after restarting.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product. Figure 3:
  3. Disconnect the data cable (USB or Ethernet, depending on how your product is set up) from the back of the product. USB cable Ethernet cable
  4. Unplug the power cord from the wall outlet. Figure 4: Unplug the power cord from the wall outlet
  5. Wait about 30 seconds.
  6. Reconnect the power cord to the product and wall outlet, and then turn on the product.
  7. Print and time a self-test again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Mar 31, 2010 | HP DeskJet 3650 InkJet Printer
The resume and power buttons are flashing on my 5550 deskjet; nothing works. The print queue is empty and there are no outstanding (manual) double-sided pages waiting. Temporarily disconnecting the ...
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Nov 12, 2009 | HP DeskJet 5550 InkJet Printer
I can scan, BUT I can't print. HP PSC 1500 windows 7
Go to control panel and check the printer status, Unplug the USB cable than right click on printer icon and click on delete. Once you do that make sure printer icon should be gone. Than restart the computer. Once computer is Up than connect the USB cable of printer and make sure while doing that , the printer should be powered on. After that printer icon will again reappear in contro panel.
Try printing, it should work
Jul 22, 2009 | HP PSC 1510 All-In-One InkJet Printer
Need to use HP Deskjet5550 to print off laptop
Since Hp have Vista driver to your printer...to install the driver...do not plug the printer...install the driver that you downloaded (run the program as Administrator)..after you install, if the installation ask for restart..restart your computer...after restart and the whole system finish his task on loading driver and dll ..then plug in your printer...it will pop up message found new hardware. click next and choose automatic find the driver.
what Cable are you using to connect?
USB a and b?
parallel port to USB? if this you need to download the driver too.
Good Lock
Mar 13, 2009 | HP DeskJet 5550 InkJet Printer
Test page from hp 3550 with out attach computer
power on your printer.
While press & hold power button open & close the top cover for 5 times and release the power button.
Sep 09, 2008 | HP DeskJet 3550 InkJet Printer
Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Sep 19, 2007 | HP Photosmart D5160 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
