Question about Apple PowerBook G4 Mac Notebook
Overheating PowerBook G4 17" 1.67Ghz
My PowerBook seems to operate normally with normal operating temperatures except for the following: Five times i have left my PowerBook for approx 4 hours only to return and find it very hot to the touch. (160 degrees F). One time the PB was in sleep mode and the other it times was shut down. Sometimes the lid was closed, sometimes open. It sits on a wood desk top plugged into the Apple power supply, a powered USB 6 port hub, and an Apple 23" flat panel display. I have a DSL modem connected via Apple Airport but the modem is switched off at the times of the overheating problems. There is adequate ventelation room all around the PB, and nothing is on top of it. The ambient room temperature is between 50 and 65 degrees F. The problems have occured between the end of March 2007 and the first of June 2007, so the overheating is not happening each time i leave the PB, only some times. I have reset the PB Power Management Unit as listed on Apple's web site. (tech article 14449) Any suggestions will be greatly appreciated.
For my pb I have changed the energy saver options to minimal, this prevents the overheating.
The overheating is due to the memory used by the applications in use. -----------> in my experience!
Posted on Apr 13, 2008
    Problem Solver:
  • 5 Answers
If you have AppleCare and your PB is less than 3 yrs old, take it in- that seems abnormal. It's really strange that your PB was heating up while it was shut down. THat indicated that there is s/thing wrong with the shutdown mechanism. Make sure the machine is hsut down before closing the lid. Let it rest a minute.
Posted on Jun 30, 2007
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Temperature gauge is at normal but coolant is coming out recovery tank when I drive it
You have trapped air in the cooling system, purge the air out of the system. You can do this by raising the car front end as high as possible and filling the coolant recovery tank to the brim leave the cap off, then run engine until it reaches operating temperature, then shut it down and run cold water over the radiator core, the coolant tank will be sucked dry most likely as the air is purged and replaced by coolant.
May 26, 2017 | Ford F150 Cars & Trucks
Www.hp.com/go/techcenter/startup
My computer is appear " The System BIOS has detected that your notebook PC was not into hibernation or shutdown to avoid overheating.The system is now operating normally.
Overheating may occur if the cooling vents are blocked or the operating temperature exceeds the specification.The notebook PC should return to normal operation once the situation is resolved."
System temperature (90D)
Apr 08, 2012 | Computers & Internet
I have a 2002 mitsubishi montero sport and we changed the thermostat, did a radiator flush and change radiator cap and the needle passes to mid point (normal) it hasnt overheated but it doesnt stay in...
Where do you live?
This has been a hot summer, bit hotter than usual due to the solar flares going on...
as long as the pointer stays within normal operating range, you must not worry... especially since you changed the thermostat and did a flush, did you make sure you got the right temperature range thermostat installed, rarely but few times that seems to be the problem, hotter thermostat gets installed by mistake.
Aug 19, 2011 | Mitsubishi Montero Sport Cars & Trucks
Hi , I am using hp pavillion dv4 1131tx laptop. My screen always randomly turns black and then shuts down after a few seconds. when i start it back up, i get this message: "The system bios has...
well your CPU centeral processing unit is overheating ..check the fan if its still working.. if its then try to clean the fan take it part and get it clean .
May 06, 2011 | Computers & Internet
Hello... I got problem with my honda odyssey. For the past 3 days, if i start the engine, after 5 min the temperature will goes up to HOT and engine indicator light-up. I turn-off the engine and then start...
Your English is very good.
From what you have described, which is a rapid over heating of the radiator coolant fluid and therefore a hot engine condition, it would appear that the thermostat in the engine's cooling system is faulty.
If the thermostat is sticking in the closed or nearly closed position temporarily, there will be no flow or very little coolant flow between the engine and the radiator and the engine will overheat.
You have advised that after the engine is shut off , and radiator coolant fluid has cooled, you re-start the engine and drive the car without the overheating condition occurring again and the radiator coolant temperature is normal. This time there is no overheating because the thermostat is working normally.
You should have the thermostat replaced as soon as possible because allowing the engine to overheat can cause very expensive engine damage.
If you had a continuing overheating condition then I would suspect both the thermostat and the water pump. However as the overheating seems to be only temporary, and clears itself after you have shut down the engine and re-started it 10 minutes later (without further overheating arising) then I think you only have a faulty thermostat.
Please also check that the electric fans which draw air through the radiator are operating. These run on a temperature sensor and will switch on automatically once the radiator coolant fluid reaches a certain temperature and then switch off again when the fluid temperature reduces. You will hear them running once they start up. If these fans are not working the radiator coolant can quickly overheat in various driving and temperature conditions because there will be insufficient air flow through the radiator to cool the fluid. If the temperature sensor is faulty or has died, or if the electric motors running the fans are faulty, the fans will not operate.
I hope this helps.
Dec 18, 2010 | Honda Odyssey Cars & Trucks
Thermofans don't kick in, but temperature seems ok
Hello... You should not be concerned... This is normal... Also, normally you should not hear the thermostat. But the Fans don't normally turn on until about 100 degrees centigrade....
Good Luck
Apr 07, 2010 | 1989 Toyota Camry
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Overheating
Pls check the thermostat. It is most likely a sticking or even stucked as that is basically its purpose, to restrict the coolant flow and allow the engine to reach operating temperature thereafter grant free flow of the coolant. It would seem that there is considerable delay in its opening and therefore the temperature rises above the normal operating temperature.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 13, 2008 | 2002 Chrysler PT Cruiser
Apple PowerBook G4 Mac Notebook Logo
947 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
