Formatting c drive
What's the correct command after "c:" to format the hard drive? [tried to load an antivirus on my laptop after loading Windows 7 Beta...BIG mistake!]
    Problem Solver:
  • 3 Answers
Yo can do this when you installing windows it asks you weather you want to format
Posted on Jan 13, 2009
Bootmrg missing
Um, start over with the Windows disk, and reinstall from scratch. If the drive has been formatted, then there's nothing left there to recover.
Jun 06, 2015 | Internet Computers & Internet
How do I format a Levono H512s hard drive with Windows 8.1 installed
If you know the brand of harddrive, down load the software from the site, a windows will not purposly kill itself, If you can you might get win 7 to format the drive, should work. you can do this in the install,
Dec 25, 2014 | Computers & Internet
Ex. hard drive will not open windows say windows will not even formate
If windows will not format the hard drive then the HDD is probably bad. Depending on the operating system you're trying to load, if it's Win XP or earlier you can still use DOS to format the drive then try loading windows onto the drive. Windows will want to format the drive again when you load the disk and that's ok because it will format the disk from FAT32 to NTFS. If it still fails then You more than likely have a bad disk that cannot be written to. One other thing you can try is to boot to command prompt and type in sfc /scannow Make sure you have windows inserted in CD drive. This will check your system if Windows is already loaded on the drive but you're having a hard time booting to it. Hope this helps
Oct 29, 2013 | Computers & Internet
Hi My pendrive is write protwcted, Pendrive is
Some pen drives have a small toggle switch with them which make the drive write protected try locating that switch. If there is no such switch then try formatting the drive preferably from safe mode. you can do this by following these steps:
1. Shutdown your computer or laptop
2. Insert USB Memory Stick into your laptop or Computer
3. Turn on laptop and then immediately start pressing (Fcool.png key then Advanced Boot Options screen will come up
4. Select Safe Mode with Command Prompt
5. After loading files if your USB Memory Stick drive letter is (G) for example then write as
6. C:\windows\system32>G: and press enter
7. G:\>format G: and press enter
8. If ask you (Y/N) then press (Y) and press enter
9. Now a full format will start which remove write protection from USB Memory Stick.
Sep 23, 2013 | Kingston Technologies 512MB DataTraveler I...
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
I want to format my c drive with the help of Dos command prompt , installed win 7 ultimate.
Formatting hard drive When booting from a Windows installation CD select the option to install Windows then you (can either delete the existing partition/s then create a new partition then you) can format the hard disk. After formatting the hard disk you can abort the Windows installation if you do not want proceed to install Windows.
You should be able to use the Windows 7 installation CD to delete the existing partition, create a new partition and format the new partition and then install Windows 7.
Apr 03, 2013 | Computers & Internet
I Bought a Vaio computer with Windows 7 and installed. I would like to install Windows XP, how can I do it?
Go to BIOS Setup, and in Boot Options change the first boot device to CDROM.
Windows doesn't like to have the same version written over it, or a lesser version written over it..
Forcing the computer to boot from the optical drive, (CD/DVD drive), corrects this.
What is the model number?
Nov 09, 2010 | Sony Computers & Internet
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computers & Internet Logo
David Payne
David Payne
