Question about Kenwood KDCBT648U
Kenwood kdc-bt648u hooking up to amp and sub wiring help?
I have a kenwood kdcbt648u installed to my truck. ran tha remote and everything back to my 1200 watt sony gtr2002 amp and from there to the subs. ive checked almost everything possible and still no subs. any ideas or solutions? i have the output setting on on the deck and all that fuses good. my 12 inch treo rsx are in new condition. anything could help. thanks.
PyroMan6x9x9
  • 150 Answers
SOURCE: Programing My Deck
Follow the below link for your manual: http://inform2.kenwoodusa.com/manuals/KDC1028.pdf Your welcome! Should you require any other assistance with this let me know Good Luck L8R
Posted on Sep 18, 2007
merle840
  • 113 Answers
SOURCE: kenwood kdc-1028
the remote is blue - the ignition wire12 volt is red - the battery line 12 volt is yellow
Posted on Mar 27, 2008
  • 631 Answers
SOURCE: install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Posted on Aug 25, 2008
Hazardsneon
  • 100 Answers
SOURCE: how to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
Posted on Aug 29, 2008
  • 191 Answers
SOURCE: amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Posted on Mar 16, 2009
I bought a car with a Kenwood KDC X 569 system and when I went to lay the remote down the system turned off I don't know if I hit a button or something but it wont turn back on please help
Kenwood Excelon KDC-X569 - Crutchfield
www.crutchfield.com > ... > All Car Stereos
Crutchfield CorporationThe Kenwood Excelon KDC-X569 CD receiver jumps out ahead of the pack, ... only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories ... HD Radio reception, and connections for building an audio system in your car. .... You can turn on/off this feature in the menu. ... Purchase accessories for this product.
Kenwood BT648U Car Audio How to reset a ... - YouTube
? 4:27
https://www.youtube.com/watch?v=NjzCs-WVPak
Feb 27, 2012 - Uploaded by Paul Tran
This is a video if you dont know how to reset a kenwood bt648u or any o... ... I was in dark ... what happened to ...
Dec 03, 2015 | Kenwood Car Audio & Video
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Nov 22, 2012 | Pioneer Car Audio & Video
How do i set the rca settings for my kenwood kdc-217
Theres no way to change the rca settings. More than likely they put out 2 volts which is more common. Some newer more expensive models put out 4. What size remote wire you using? Try using a bigger (smaller #) gauge wire. That will give it a boost if your using the one that came with an amp kit. What kind of speakers? What kind of amp? If amp is mutli channel and only one sub then you will need to bridge the amp. Try different combos of + and - to see which gives the best. Also make sure everything is turned up on the amp and set to low pass frequency.
Jun 22, 2010 | Kenwood KDC-217 CD Player
I tried hooing up my amp and subs but i get
make sure u have
power source with inline fuse working.
a ground line getting a good ground(scratch paint off care frame screw it down).
remote line from amp connected to the remote line on the radio.
and make sure you have rca running to the sub input on your radio.
and your speakers are connected.
Mar 25, 2010 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-135 remote wire
should be a solid blue wire
Jul 24, 2009 | Kenwood KDC-135 CD Player
No sound from my front and back speakers in my van ive got subs
Make sure that when you hooked up your 4 channel amp to the remote turn on lead it is the same as the sub. Only hook amps to the Blue w/ white strip. The solid blue is power antenna lead and will lose power when on CD, ipod etc and only stays powered when the Tuner is on. Hope this fixes your problem.
Jun 03, 2009 | Kenwood KDC-MP428 CD Player
Problems with kenwood kdc-mp2028
The remote from the amp should be connected to the remote (blue wire) or power antena wire from the radio.
May 15, 2009 | Kenwood KDC-MP235 CD Player
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Kenwood kdc-1028
Mar 26, 2008 | Kenwood KDC-1028 CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Kenwood KDCBT648U Logo
44 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
