Question about Samsung Bnib Hm3600 Bluetooth Wireless Headset For Apple,lg,motorola,blackberry
Samsung HM3600 Bluetooth Wireless Headset
How to activate the voice proms
4 Suggested Answers
SOURCE: bluetooth headset
THank you thank you.. you helped me solved my problem 0000 password
Posted on May 29, 2008
worldvet
  • 859 Answers
SOURCE: Samsung WEP200 Headset
Hello Sir,
You must be frustrated by this problem. It should be easy to solve. All units transmitting on an open channel have a unique identifier. This is the Pass Key.
1.) Check under the transmitter and there should be some numbers. The one above the bar code is usually the passkey, but it could be another on the label so write them all down.
2.) Click on the Blue icon next to your time display in the System Tray.
3.) Double Click your bluetooth headset and when prompted for the passkey enter the first number you wrote down. If that does't work try the others. One of them is your passkey.
If you need further assistance comment back to me and I'll be glad to help.
Kind Regards,
Worldvet
Posted on Jun 01, 2008
vanherringto
  • 1738 Answers
SOURCE: samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Posted on Feb 04, 2010
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do you make a call ,using 903+Bluetooth Headphones
To make a call using your 903 you can dial it on your phone and you can proceed that way, or you can do a 2 second press on your headset using voice command.
Good luck from Headsets Direct!
May 01, 2011 | Plantronics Backbeat 903 Bluetooth...
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Tips & Warnings
Good luck to you..
Feb 01, 2011 | Cell Phones
Blackberry 8530 cannot find / pair with bluetooth Samsung stereo headset. Tried putting both into discoverable mode, no help. This headset will pair with my Blackberry 8320 phone, but the music speeds...
1. Turn on Bluetooth headset and Blackberry hand-held.
2. Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
3. Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window
4. Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list
5. Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
1. Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset 2. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
3. Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Dec 03, 2010 | Insignia Bluetooth Wireless Headphones...
Receiving calls on Parrot minikit
The crossing test with an other phone will give you the explanation.
Cause the software version of one or the other product can be the reason why.
Mar 02, 2010 | Parrot MINIKIT Bluetooth Hands-Free Kit...
My voice is garbled and the people I call using a LG HBM-770 bluetooth wireless headset can not understand me. Suggestions??
tried pairing with a different phone and turned up the volume button...don't know which change made it work but it worked fine. So I'm guessing it might have been the voume was not set correcttly.
May 27, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Voice service kills audio with insignia wireless headset in Second Life
perhaps it stills has an option to assume total priority over anything else for the particular program you are running, check its details and settings,,,,all else fails removeit....it cant, or shouldnt climb out of the trash can.....**crosses finger**....
Nov 03, 2008 | Insignia Bluetooth Wireless Headphones...
Samsung Bnib Hm3600 Bluetooth Wireless Headset For Apple,lg,motorola,blackberry Logo
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
