Question about Brother Sewing Machines
How to thread a brother charger 491 sewing machine
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: thread getting stuck
We had he same problem with no solutions posted. Solution: First, make sure the bobbin case is clean. Ours was slightly rusted. The rust acted like a fine sand paper keeping the thread from encircling the bobbin. We used an metal cleaning powder to remove it. we also noticed that the entire bobbin area of the machine was dirty and had oxidation on the metal. We cleaned that as well.
Second, we checked the hook's action. (We took off the ring around the bobbin and removed the bobbin case as well. we left the hook in the machine and then turned the machine. We watched for how well the hook grabbed the thread from the needle.) We noticed that the hook was slightly slow and was not grabbing the thread. The hole in the needle was slightly above the hook as the needle retreated and hook spun around.
To repair this, we took off the front plastic cover (the side facing the operator). There are screws on both sides of the machine for this. After the cover is removed, you will notice a flat bar going from top to bottom about 1/3 from the right of the machine. This bar has four screws. This bar is the timing adjustment for the bobbin hook. Loosen all four screws. If you turn the bobbin by hand, you will see the bar flex back and forth. Turn the bobbin all the way to the right and tighten the screws. The hook should now catch the thread properly.
Posted on Aug 30, 2008
Jimsta01
  • 405 Answers
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: MY BROTHER MACHINE NO. LS-2125i THREAD BREAKING WHEN SEWING?
Thread brekage can be caused by several things but start simple by taking off the needle plate then thoroughly clean the sewing mechanism and add a few drops of oil, then check the threading is correct. replace the needle. Always use quality threads and make sure that the thread is not to heavy for the size of the needle (it should pass easily through the needles eye). check that the needle hole in the plate is not bent or damaged and peppered with needle marks, a damaged plate will cause many problems. Finally, make sure that the tensions are not too tight this can be a major cause of thread breakage especially if poor quality thread is used. ( check thread by breaking it by hand, it should offer good resistance to breakage, if it breaks easily then discard it. hope this is useful, best of luck.
Posted on Apr 14, 2010
  • 36 Answers
SOURCE: my brother sewing machine won't pick up the thread...
If it is the correct needle length, and the needle is in correctly and threaded correctly, then the machine is out of time.
Posted on May 23, 2010
Brother 661 charger keeps breaking the thread on the needle when it goes down in the machine
Install a new needle. Remove the thread from the upper threader. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the tension to the midway point.
Jan 19, 2017 | Brother Sewing Machines
How do I thread a Brother charger 666 sewing machine?
The owner's manual is probably the best guide for your machine, however, this link may be helpful:
Brother 666 sewing machine Google Search
Nov 20, 2015 | Brother Sewing Machines
Brother vx-1435, needle cuts thread when sewing
change the needle it could have a burr or be damaged
also check the needle plate & bobbin area for burrs
Apr 09, 2012 | Brother VX1435 Mechanical Sewing Machine
I have a brother charger 491 sewing machine and am looking for an operating manuel
Call Brother at 1-877-276-8437 and ask them if they have a free download. I didn't see it on their website, www.brother-usa.com but maybe I missed it. You can also google it and see if someone has it that it can be downloaded. Good luck
Jan 08, 2011 | Brother Sewing Machines
Help in threading singer 491
that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Oct 01, 2009 | Singer 5050 Mechanical Sewing Machine
My brother sewing machine jams threads under the needle and will not go, all the thread has to be pulled out gently as not to break the machine. It will not sew at all now.
hi there, why is it that i can't sew at all..both thread are not working instead eating each other thread under....but i have a good brother ls 2125. ty...
Mar 08, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125 how to thread bobbin
all manuals for a brother sewing machine are downloadable at www.brother-usa.com
Apr 02, 2008 | Brother LS-2125 Mechanical Sewing Machine
Feb 22, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
227 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
