FixYa.com
Tags:
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Picture doesn't fit screen (by 8 users)
posted by Logandolf on Jun 11, 2007
My RCA D52W20 52 in. Rear Projection projects a picture bigger than 52 in. it is like a 54 in. picture. It cuts off scores, scrolling stats and news on the bottom of the screen. Anyone have an idea???
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by nerrissa, posted on Jul 08, 2008
screen format, picture is cut off at the top.
Comment by Guest, posted on Jul 08, 2008
wrong screen format, picture is cut off at top
Comment by Guest, posted on Jul 05, 2008
I have a sony wega ldp hd tv(42") which will cut some of the picture off. I have tried using the wega gate to fix the screen, but no good. The logos are half hidden or chopped off. Please help.
Comment by Guest, posted on Feb 29, 2008
I have the same problem, but only if I'm sending a 1080i signal. It also shifts the picture to the right so that the picture isn't centered on the screen.
Comment by Guest, posted on Jan 01, 2008
I had the same problem. If you have a cox or cable one remote that works with your TV. You want to push the TV button on top and on the remote there should be 4 arrows pointing up down right and left. Push the button to the right or left and it should change the zoom feature to fit what you want.
Best Solution
posted on Dec 30, 2007
Helpful (85)
lizk0103
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
No help what so ever! I've tried that numerous times. Auto formatting is the only option as there is not option for manually changing the ratio. Any other suggestions?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 11, 2007
Thanks for Trying (70)
premtech
Rank:Guru Guru
Rating: 89%, 773 votes
Go into the menu and select picture settings and then advanced picture settings. I'm not sure on that model that you can manually change the aspect ratio from zoom to 16:9 or 4:3 ect... But select Auto Format and the TV will pre-select the correct format for viewing.....
Any questions just let me know.
Bill
Rating Locked! (?) Logandolf has rated this solution as Thanks for Trying
Solution #3
posted on Jul 10, 2008
Not Rated (0)
walkers1969
Rating: 0%, 0 votes
Same aspect adjustment problems are in the Samsung 67"..I cannot see the score of the GAME!!!!
Solution #4
posted on May 14, 2008
Not Rated (0)
adamb1tch
Rating: 0%, 0 votes
my rca truflat tv projects a larger picture than the screen, its really annoying i play my 360 and it cuts off alot of the screen so i cant read messages on the left and right of the tv screen, there are no options to adjust the ratio so all there really is to do is to buy a new t.v. if you are reading this i recomend you do not waste your money on a TruFlat RCA T.V. If somebody has a solution please let me know it would save me money and would make me very pleased.
Solution #5
posted on Jan 02, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Why can't we get an answer that might help ??
Solution #6
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
if that's a dlp unit they are garbage ive had two and both died in same manner in less than a year one the bulb blew on in three months after purchase then went blank and started making a high pitched squealing sound had to argue with rca cust support after repair shop said they could not fix it rca finally sent me a new one but with less features after i argued with them for another three that one did the same thing after three months now rca wont even talk to me and ive got a 100lbs paperweight that does nothing i was told it was the light engine at a cost of around a grand for part so don't waste your money on a repair shop mine is still sitting there blank and i understand this is a common problem from checking the web just roll it in the back yard spend you money on one that will work im going lcd this time and i do houseld appliances not tvs so dont worry about rating me i like to pass this info on every chance i get just to help my friends at rca
Solution #7
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
That didn't help at all - there's no option to manually change the aspect ratio
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection HDTV-Ready...
PICTURE TO LARGE FOR THE SCREEN...
I can;t get the zoom bottoms to... Answer This...
**** tv
ghosting red, blue, green. Red,... Answer This...
green light flashes
tv worked fine when shut off... Answer This...
damn tv
there was a post up top that... Answer This...
Convergence off on Digital...
I have a RCA D52W20 52 in. Rear... Answer This...
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 28, 2007
picture dosen't fit the screen. Picture is larger than the screen. Aspect only adjusts upper and lower screen, not left to right. Tried unplugging everything, letting it set and hope it would default back to normal...however, didn't work. HELP! Thanks
Comment by veryanointed, posted on Nov 17, 2007
My D52W26 rca is about a year old. Recently it will sometimes project a bigger picture than the size of the screen but whats more annoying is that it will for no apparent reason go to a 4:3 aspect ratio. This model doesn't even have that option for me to pick. The only option is the auto format(in advanced pic settings), which when i pick the picture just goes back to 4:3 and when i turn off auto format doesn't seem to matter. Does 3:2 pull down(off, on or advanced) have anything to do with it, Warranty issue? Please help!
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
