Question about Sherwood Am Fm Stereo Receiver Rx-4103 2 Channel 210 Watt Amp With Remote
Sherwood am/fm stereo receiver rx 2010 - Sherwood Am Fm Stereo Receiver Rx-4103 2 Channel 210 Watt Amp With Remote
ronaldsuboc
  • 449 Answers
SOURCE: I have a Sherwood RX-2030R,
hi!!!
try to bring in the service
center near you! you can't repair that
b coz you will replaced the tuner board
for that?
Posted on Nov 06, 2008
  • 7 Answers
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: sherwood rx-4105 output transistors
You can also use 2SD2560 and 2SB1647 130watt 150volt 15amp transistor, but it may require some rebiasing the on output transistors. Sherwood have used these transistors in their older model receivers. I just replaced those transistors in my Sherwood RX-4105 Receiver, and they work good as well.
Before I install those transistor. I did a out of circuit 20volt 4amp DC current test to a 4ohm resistor @ 200watt load to compare 2SD2560 / 2SB1647 to the B2510/B1510 mounting them on 5 square inch, 1/8" thick piece of Aluminum, and the results of the test, the 2SD2560 / 2SB1647 heats up in 60 seconds to around 120 degrees F, and the B2510 and D1510 heats up in 30 seconds to around 120 degrees F.
Posted on May 04, 2009
SOURCE: does a Sherwood rx-4103 have a circuit breaker?
i have the same problem with mine and i cant seem to figure it out... it clicks off around 4 seconds
Posted on Aug 30, 2009
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    I just came home with the sherwood am fm stereo reciever model no rx-4109 and connected speakers, but no sound is coming out
    turn the unit on
    press a button for am or fm
    select a station frequency
    still not working take it back for a warranty check / replacement
    AFTER you have read the operatiors manual
    Jan 24, 2017 | Sherwood Audio Players & Recorders
    How do I connect my RX-4109 to a Crown power Amp?
    If your Sherwood has preamp outputs, you can connect directly to the power amp inputs.
    Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
    Antenna is broken
    Which are we talking about? AM or FM. Is it the socket where the aerial goes?
    Jul 29, 2013 | Sherwood RX-4105 Receiver
    I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
    You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
    Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
    Does the sherwood rx 4105 receiver have analog or digital inputs
    Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
    Feb 12, 2013 | Sherwood RX-4105 Receiver
    What is a compatible turntable for my Sherwood rx-4109 receiver?
    many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
    Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
    Can I download manual for RX 4109?
    Hi,here is the link for your download...
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    http://www.sherwoodusa.com/prod_rx4109.html
    RX-4109 Remote Controlled Stereo Receiver with Phono Section
    Unlike the budget stereo receivers now flooding the entry-level price points at dealers across the country, the Sherwood RX-4109 is designed and built in-house with the same quality and attention to detail we have been bringing to our audio gear for the last 50 years.
    With 105 Watts RMS per channel, phono section, binding posts, a versatile remote control and switching for two pairs of loudspeakers, the only thing that bespeaks the word "budget" about the RX-4109 is its modest cost.
    MSRP 179.95
    Jun 22, 2011 | Sherwood RX-4109
    Does a Sherwood rx-4103 have a circuit breaker?
    Apr 07, 2009 | Sherwood RX-4103 Receiver
    Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
    You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
    Dec 17, 2008 | Audio Players & Recorders
    FM Tuner in Sherwood RX-4105 stopped working
    Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
    If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
    If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
    Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
    Dec 02, 2008 | Sherwood RX-4105 Receiver
    Sherwood Am Fm Stereo Receiver Rx-4103 2 Channel 210 Watt Amp With Remote Logo
    119 people viewed this question
    Top Sherwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
