Question about Kohler Electrical Supplies
Kohler 8.5/RES Generator running in auto mode???
My Kohler 8.5/12RES was running the other day in auto mode, but there had been no power interruption from the grid?
    Sergeant:
  • 431 Answers
Can u elaborte the question please
Posted on Jan 13, 2009
  • nematics
    nematics Jan 13, 2009
    try to reset machine
How can I reset the "programmed exercise mode" on my Kohler 12 RES generator
You will likely need to reference your instruction manual for that specific control panel.
Aug 07, 2016 | Kohler 12 kW Emergency Power System -...
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
Kohler 12K RES where are links for the installation /setup of the controller? thanks
The 12RESL has no user setup. That's part of lower cost on the DC 2200 controller versus an ADC 2100 or ADC-RES controller that came with the 12 / 17 / 18 RES models. Here is a link for the ADC 2100 Operation / Installtion manual though. http://www.scribd.com/doc/60318571/Kohler-8-5-12RES-Install
Sep 14, 2011 | Kohler 12 kW Emergency Power System -...
Kohler 12res installed 06/06, replaced controller in Dec 10, has worked fine since . This past weekend with storm, generator started and has run for 3 days , generator shut down with SCFO code - which...
SCFO is either what is displayed just before it cranks or when it is first powered up. Sounds like the controller may have forgotten what engine its running or is getting a bad run signal from the start switch. In either case a 1 year old controller should not be doing this. I would try having a local dealer doing a firmware update as there were quite a few for this controller and if this doesn't fix the problem I would start talking warranty with whoever replaced the controller.
Sep 01, 2011 | Kohler 12 kW Emergency Power System -...
Can some one tell me what oil and air filter to buy for a Kohler 12res LPG generator?
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
Dec 01, 2010 | Kohler 12 kW Emergency Power System -...
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler 12res AC breaker flipping with no error listed
wat size c/breaker
6600 divide 240 = amp
rule of thumb
Aug 16, 2009 | Kohler 12 kW Emergency Power System -...
Running when in standby mode
Are you sure this is not normal?
Read your manual.
Most of the larger generators do a test run once a week or so to make sure everything is working ok in case of a power falure.
Jan 13, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
161 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
