Question about Samsung Washing Machines
Samsung WF306BHW/XAA front load washer leaking
The drain hose has been replaced and the machine leaks on the bottom on the left side and the front
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
beltronic205
  • 1474 Answers
SOURCE: Washing machine is leaking water out of the bottom
Leak could be a few things, Pump depending on what side its on /bangs, are they electrical ?
Posted on Sep 30, 2009
  • 66 Answers
SOURCE: I have an LG WM2277HW front load washer that is
check ur inlet hoses on the outside of machine, also check the connections inside the panel in back
Posted on May 08, 2010
  • 22 Answers
SOURCE: Haier Washer/Dryer HWD1000 water leak from the
Check the button trap. Little door at front bottom right corner. There is a big screw in plug that has to be closed very tightly. Also check the plug gasket is clean.
Posted on Aug 12, 2010
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
I HAVE A LEAK FROM RIGHT BOTTOM OF A SAMSUNG WF448AAP/XXA-000 FROMT LOAD WASHER ONLY HAPPENS DURING RINSE CYLCE
Hello Harlan;
My name is Peter. I am a retired field service appliance technician.
Your drain hose is in the back on the right hand side. This is a rubber hose. After a time the rubber may be dry rotted and leak or become partly clogged with soap residue.
Once completing the wash cycle the soapy water may have not completely drained due to a partly clogged drain hose by the time the rinse cycle is complete flooding the washer drain pan.
You do not have water in the bottom of the washer because your pump removed it all, but at a slower rate
Ok, Lets fix this ourselves:
1.) On the bottom right front of your washed is a leveling leg.
turn the leveling leg one full turn clockwise. The right front may be pitched down, causing the drain pan level on this corner to be high. Your washer through vibration may have moved slightly. This is not going to solve the problem.
2.) Pull your washing machine out so you can see the drain hose. Run some laundry on heavy load. Observe to see if your drain hose is leaking. Your hose clamps may be loose and require tightening. If it is leaking it needs to be replaced.
3.) Even if your drain hose is not leaking it must be obstructed, flooding the bottom of your unit. This is easily replaced.
The part number for your drain hose is DC97-12534D. It cast about $24.00.
Nov 24, 2014 | Samsung Washing Machines
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
Machine wont open code SE
SE means drain error, Sounds like your drain is blocked. You may have access to it through the front at the bottom but If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Mar 02, 2011 | Samsung WF306BHW High Efficiency Front...
I have a Samsung WF316LAS/XAA Washing Machine, has worked great for 4 years. Just started pouring water out of the soap dispenser drawer when in a washing cycle. Any advise
take off the top and check the hose that leads to the tub may be plugged . May have to take the boot(door)seal off front under door to access lower end.
Nov 20, 2010 | Samsung WF306BHW High Efficiency Front...
Samsung washer bouncing into wall.and leaking
did you remove the transit bolts located at the rear of the machine?
Oct 24, 2009 | Washing Machines
Leak samsung front load washer
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
learn more detailed information about the recall by visiting Whirlpool...or Samsung's at www.samsung.com/washerrecall.
Hope you find useful!
Regards Faggly
Mar 19, 2008 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
