Question about FreeMotion 750 Interactive Treadmill
I have an electrical problem with my freemotion treadmill, ita has been tested by an electricain and it is getting power to the circuit board but now out of it. where can i get a new circuit board?
3 Suggested Answers
  • 15 Answers
SOURCE: my freemotion treadmill is slipping,
ajusting the belt tension rollers, front and rear rollers tighten with usually a allen bolt ajustment tool
Posted on Oct 25, 2010
ercupa190
  • 12223 Answers
SOURCE: Freemotion 790 Interactive treadmill belt squeaks as soon as you turn it on
Inmediately LUBE the deck belt, this happen because the lack of maintenance schedule, see your instr. manual and follow the steps.
2) Lube the rollers bearing use the wd-40
see the video attached.
God bless you
Posted on Dec 07, 2012
Just got it and it will not power on. There is a red light on the circuit board inside of motor housing
http://www.sportsmith.net/images/product_support%5CFreeMotion%20Fitness%5Ctreadmills%5Cfmtl8505p2_freemotion_treadmill_owners_manual.pdf
Mar 30, 2015 | FreeMotion 775 Treadmill
Treadmill is receiving power but will not turn on
It sounds like you have verified power from the wall. I would also verify that the power cord is getting the power from the wall to the machine. If this tests good, continue to follow the power until it stops. By this I mean, make sure you are getting power past the on/off circuit breaker. If you are getting power past this and into the lower board, chances are the lower board is not sending power to upper board. This could be the cause of a faulty lower board or something as simple as a short in the wiring between the upper and lower board. You can check the wiring by using a multimeter to confirm continuity. The attached link is a quick guide on using a multimeter. Video about Multimeter Testing
Apr 12, 2014 | FreeMotion 775 Treadmill Exercise Machine
I have a Freemotion XTR90 treadmill that stops / resets after 5 min of use.
see the video attached, Lube the rollers bearing too Front+back. However you must test the main motor, measure the input voltage terminal at motor, if there ARE AND THE motor NOT run the motor is faulty. 2) test the output voltage terminal control board, for input voltage motor, if there ARE NOT the board is faulty. see the diagram attached.
Nov 26, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
I start the track and it moves until I step on it then it stops
see the video and lube too the rollers bearing front and back.
However if the problem persist. Test the input voltage motor if there are the motor is faulty. Test the output voltage terminal control board if there are Not FOR the input voltage motor, the board is Faulty. replace
Oct 08, 2013 | FreeMotion Xtr 90 Treadmill By Free Motion
Freemotion XTE Elliptical display won't turn on at all
please test the battery by new ones, clean the contacts batteries and replace . test the reed switch see the diagram attached. However you must download from www. fitness.manualsonline.com
God bless youc719c602-5572-4506-9d14-437751e71106.gifc3db8187-db09-41b3-90bb-d7e9652e1ebf.gif
Jun 04, 2013 | FreeMotion Fitness xte Elliptical Trainer
I can't get my treadmill to turn on
1) test the wall outlet with another device such LAMP desk
2) test the c.breaker from your home if device is NOT turn ON.
3) If turn ON, go to reset the c.breaker or fuse replace, Try again.
4) Replace the power cord if is defective.
5) see the diagram attached for better troubleshooting.
Aug 27, 2012 | FreeMotion 750 Interactive Treadmill 12510...
Freemotion xtr90 treadmill will start and run, but belt stops abruptly.
please LUBE the deck belt inmediately.
2) LUbe the rollers bearing too
3) test the input voltage motor , if there are the motor need repair.
4) Test the output motor board,if there are NOT voltage the board is faulty.
God bless you
Aug 26, 2012 | FreeMotion Xtr 90 Treadmill By Free Motion
I have a tredmill that quit.Is there a fuse that could be blown and where is it?
1) Unplug the machine, and test the fuse.
2) See is if there some componenet BURN, such: resistor, diode, capacitor, triac, or SCR. AND tEST IT.
3) See the block diagram, the fuse can be located in the boards, or near to the main switch.
God bless you
Jun 09, 2012 | FreeMotion Emotion Tredmill Tv Treadmill...
Treadmill turns electricity off
this a short circut problem. 2) test the power cord 3) Test the fuse blown, 4) reset teh circuit breaker and reset 5) Test the capacitor 6)Test the coil 7( Test the motor8) Test the main board.
see the block diagram
God bless you
May 10, 2012 | Exercise & Fitness
Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Apr 06, 2010 | Icon Exercise & Fitness
FreeMotion 750 Interactive Treadmill Logo
24 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
