Question about HP w1907 LCD Monitor
Why is my HP 1740 Monitor going off to sleep mode and does not allow me access to my PC
Mark_Webber
  • 472 Answers
SOURCE: Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
SOURCE: monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Posted on Sep 13, 2008
SOURCE: monito going to sleep
I have the same problem. Monitor states going to sleep and the pc goes dead
Posted on Oct 10, 2008
rockitman187
  • 2559 Answers
SOURCE: hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
  1. Click start,Control panel,
  2. Double click Power options,
  3. On the left menu bar,Click Change when the computer sleeps,Change "turn off the display" to never,
  4. Go down to the botton and select "Change advance power settings,
  5. Scroll down to Display and click the + symbol,
  6. Click the + symbol beside "Turn off display after" change to never,
  7. Click on the next plug + symbol beside Adaptive display and change to off (You may or may not have the adaptive setting)
  8. Click apply ,click ok,
  9. Restart your computer.
If you are running windows Xp
  1. Right click on an open area on the desktop
  2. Click properties
  3. click the screen saver tab
  4. Click the power button at the bottom
  5. Change the "Turn off monitor settings"To Never
  6. Retart computer
if this doesn't fix your problem,please let me know
Please rate this a fixya
Posted on Feb 02, 2009
  • 156 Answers
SOURCE: Monitor says No input signal and going to sleep.
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
Posted on Nov 30, 2009
Will a HP 1740 monitor work?
you may choose another resolution in live monitor in DVR setting
Jan 21, 2016 | Zmodo 8 Channel H.264 Surveillance...
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
Yesterday I was on the computer and the screen just went jagged with colors, best way to describe that. I pulled the plug since was was getting no response from ctrl alt+ delete. Or my big brother keyboard...
you might pressed a key on the monitor repress it and enable the monitor or else just remove ram from the cpu and clean it and replug it might it solve your problem
the last solution is to just format your pc
Jun 03, 2017 | HP Pavilion s3000e (GC387AV) PC Desktop
HP w1907 LCD Monitor goes to sleep by displaying a "monitor is going to sleep"error after turning on the computer and doesnt display anything. It works intermittently, in that, if the computer has been...
so if you test the monitor on a known good PC it does what?
fails, then its the monitor
works then its the failing PC
all old HP monitors pre 2010 many had a sleep timer
so push the menu key on the monitor
then look for sleep timer and turn it off,
the monitor defaults to that mode, so dont push reset monitor or bam back to sleep mode it goes. so turn it off again.
all this is in the manual, lost yours, wana read it first?
read page 4.7 see that? (osd +advanced +) power saver OFF
https://www.manualslib.com/manual/418165/Hp-W1907-19-Lcd-Monitor.html?page=25#manual
if that fails to fix it (tested on 2 PC ) the PC1 is bad.
that be a whole other WALL OF TEXt, ask.
Dec 10, 2017 | HP w1907 LCD Monitor
Hp l2208w going sleep
Hi
I am sorry that the Monitor is going to sleep mode. Are you experiencing the same issue with different Tower or CPU? Turn OFF the monitor and power cycle it after a minute and check if the same issue persists. Also, reinstall the Video Driver.
Jul 16, 2010 | HP L2208W Monitor
I have an HP w2207 flat screen monitor. I have to
I stoped the monitor from sleeping by going into the montitor's menu, management, then sleep. Turn on the never allow to sleep mode. We were having some of your mentioned issues with the icons and with the monitor not waking up. This fixed that. Now the computer will go to sleep and when started the monitor comes on instantly.
Mar 23, 2010 | HP Computers & Internet
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Computer asleep
I have to keep my pc in safemode now as mine is also in constant sleep mode and I can not get it out, It is the only way it will load up! :-(
Apr 09, 2009 | HP vs15 15"LCD Flat Panel Monitor
HP w1907 LCD Monitor Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
