Question about Hisense Refrigerators
I bought hisense HR6TFF222 a month ago, and then week later there's a problem occurs on the fridge part (the lower section), it's not working very well, it's warm as in room temperature while the freezer (upper section) part is working well.
  • kALTE nASE
    kALTE nASE Apr 25, 2017
    Please note,
    For the layperson (Customer), the perception can be: "the freezer-part is working well".
    How do we know that the FREEZER-part IS working well ??
    The food is frozen; You can feel the food, it is hard /solid and cold.
    Which does NOT proof, that the freezer works well. It may not.
    The temperature should be measured in the FREEZER-Partition. (IR/digital Thermometer).
    The temperature measured, is often ONLY minus -3 or -8 Degrees Celsius (Too Warm).
    It is easy to suspect,
    that the Freezer is functioning properly.
    If the FREEZER-part is working well, the Temperature should be minus -12. or -22. or about -18 Celsius ( not Fahrenheit),
    this depends on the temperature setting at the temperature Control--
    The causes can be:
    1)
    A faulty EVAPORATOR-FAN MOTOR, inside the
    Freezer. It is not rotating, the result
    will be: No cold Air flowing.
    2)
    The Cold-AIR FLOW from the Freezer to the lower Fridge-Compartment is BLOCKED-
    REASON,
    The EVAPORATOR in the Freezer IS ICED-UP,
    The ICE BUILD-UP is blocking the fins &
    restricting or stopping the cold air to flow
    through the evaporator.
    The ICE BUILD-UP up can be caused by:
    Problems with the 'Automatic Defrost' :
    a) A defective DEFROST HEATER,
    This causes the Evaporator to ice-up. -
    b) A faulty DEFROST-TIMER.
    It does not switch on the Heater.
    This will cause the Evaporator to
    freeze-up, after about 2 to 4 days.
    ( see 5) TIMER failure Check)
    c) A faulty DEFROST-TERMINATION THERMOSTAT.
    This thermostat switches the heater off,
    to end the normal Defrosting Process.
    If faulty, the Heater is NOT switch off.
    The Heater continues to heat
    and the temperature keeps rising.
    The Thermal-Fuse will then activate, to
    prevent a fire within the Refrigerator.
    d) The THERMAL-FUSE melted, has 'activated'-
    This Fuse is a safety device, to limit
    an unsafe high temperature during the
    Defrosting Process.
    When 'activated' the Defrost-Heater stops
    heating. [ see b) ]
    If the Thermal Fuse 'activates', the
    Defrost Termination Thermostat is faulty.
    3)
    A BLOCKED DRAIN-PIPE (located in the Freezer) results in filling up the Drain-dish with condensate, which is molten ice, flowing from the Evaporator & after a few days, the Dish-Tray will overflow.
    4)
    When the Drain-Dish, which is located behind the rear wall inside the Freezer, is overflowing,
    sometimes water drops can be noticed in the Refrigerator, (the lower part) dripping from the top, near the rear wall.Or water is in the floor of the fridge.
    5)
    TIMER Failure Check
    possibilities:
    the Timer-motor fails to rotate, Timer gears or contacts faulty-
    The timer-motor rotation can be observed through 3 or 4 small holes in the plastic case of the timer-
    It is best to first remove the thin round plastic label, that covers the holes.
    Then point a strong focussed narrow beam of light on the holes, now look through the holes.
    The armature (the part that turns) can now be
    recognised, if the light is shining at the correct angle.
    I am happy when I can help someone-
    Be kind to each other-
    Klaus
    Hisense Service Technician
    Elektromeister
    New Friend:
Ive Recently turned my fridge back on after being in storage for 6mths and it just doesnt seem to be getting cool, the temp is switching from the freezer to bottom part of the fridge.. I have warranty but i have misplaced the reciept..
Posted on Mar 21, 2016
Ive just had the same issue as the op with the same model fridge. The warranty center said to adjust the front level feet to elivate the front of the unit open both doors , defrost for 8-12 hours at least. This seems to be a problem in the colder months of the year. Once a full defrost has occurred level the feet again , and turn your fridge back on. Problem solved
Posted on Jun 05, 2013
5 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Posted on Nov 09, 2007
  • 90 Answers
SOURCE: FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Posted on Jan 05, 2008
MNTECH
  • 1543 Answers
SOURCE: I have a GE GSS25WGMD BB Fridge. I have already
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Posted on Jun 09, 2009
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
I bought a hisense fridge a month ago, it was Ok when we connected just for couple of days, I turned the temperature up a bit so the freezer can be colder, but now
Hisense is a company that makes cheap budget end televisions. Sounds like the defrost timer may have failed. The cold is created at the rear of the freezer and cold air is vented to the fridge. Have it looked at under warranty.
Feb 02, 2017 | Frost Refrigerators
Bought Bush fridge freezer 13 months ago. fridge broke down twice with same problem. defrost timer. Can i complain to bush
you can ask again for it to be looked at repaired
even if it is out of warranty
fixed twice during warranty period (for free i hope )
if point of sale will not refund or repair or replace fridge freezer
you will need lots of paper work receipts of repairs and calls and conversations made etc etc
then you have to take the company /manufacturer of the bush fridge freezer to small claims court and try to get money back
parts list
http://www.espares.co.uk/browse/at1084ma732/fridges-and-freezers/bush
Jun 30, 2016 | Bush Refrigerators
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
Samsung RSH!NHSW fridge freezer Freezer fine. Fridge icing up. temperature between 8 and 10. Will not go lower. In cool place. Why?
We've just had exactly the same problem on our RSH1DBRS. After a recommendation from a friend of ours, we bought a DIY kit from Appliance DIY Repairs. It's a very simple repair, and ours is working just great. We had Comet out to it a month ago, but whatever they did never worked, and it went wrong again within a week. So it looks like the DIY idea worked!!!!!
Feb 07, 2011 | Samsung Refrigerators
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerators Logo
1,051 people viewed this question
Top Hisense Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Hisense Refrigerator Expert? Answer questions, earn points and help others
