Question about Bosch Axxis WFL 2060 Front Load Washer
Servis ecocare 1000, spinning to fast on aggitate,
Hi just asking if you have any idea what causes this, the motor spins to fast on agitate, it skips through the program faster as well, and it doesnt spin any faster on the spin cycle and it is very intermitant.It does this on all cycles. It also intermitantly jumps about! Has done this previously, but then sorted itself. Many thanks for any advice.
  • s_collyer Jan 15, 2009
    Dont know if you will get this reply, but thanks for your help. It was the magnet. It had slid back, and wasnt contacting properly. Thought it was a new washer time!!! tahnks steve.
  • Bosch Master
  • 3,463 Answers
It sounds like the speed control is acting up that controls the speed of the motor..
This is usually built into the main control board, and means replacing the unit. the only other possibility , is if the motor has a thing called the tacho magnet,this is to be found on the end of the motor away from the drive pully.
What you are looking for is a round magnet about 20mm in diameter, if there is one, check to see if it is loose or broken as this can effect the speed of the motor.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
May 18, 2010 | Washing Machines
What holes
Open the drawer at the top left of the front of your machine: you will see 3 compartments: right is prewash, middle is for softener, left is for wash. WATCH OUT- these machines do not need as much washing powder as the american models-putting too much soap could damage your machine and lenghthen the cycles.... I use half of what I used in my previous american washer.... do not be surprised either by the spinning cycle: before going full blown into spinning the machine has sensors that perit autobalancing of the laundry. You must not load laundry above 3/4 of the diameter of the drum.
Jul 27, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Making an awful ratcheting noise during aggitation and spin cycles
Under the agitator there is a rachet mechanism that works the agitator. If it is stripped, it will skip until the next good tooth.. when it fails entirely the agitater will stop going back and forth. Its nylon and age along with overloading hastens its dearg.. If you can get the parts you can replace it yourself without difficulty. There is a single bolt in the center of the agitator top . Remove and loft agiyator straight up.
Jun 03, 2009 | Maytag Legacy Series Top Load Washer
Roper top load washing machine that won't aggitate
Hi, It is most likley that the coupler is bad. The coupler connects the motor to the transmission. If the motor runs and you get neither spin or agitate, this is the most common problem. If this is something you want to try and fix, you can go to 222.whirlpoolsurplusparts.com and there I have a detailed article on how to change the coupler.
I hope this helps you. If I can assist you further, please let me know.
Thanks,
Vic
May 11, 2009 | Kenmore 23822 Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Servis m6160w logic 1600 tripping rcd
many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
Aug 10, 2008 | Washing Machines
Servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
166 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
