Question about Sewing Machines
Brother XL 5130. I just got this machine and the feed dogs seem to be in the 'down' position, although I can't find a lever anywhere to move them up. In some of the forum, it suggests that
  • Sewing Machines Master
  • 1,564 Answers
Http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Look up "darning" and it shows a feed dog cover so that means this machine does not have dropping feed dogs.
Now that that is out of the way... most machines have the ability to adjust the height of the feed dogs. But without seeing your machine I can't advise you. It might be better to go have the machine adjusted and serviced.
Posted on Dec 12, 2012
SOURCE: Feed Dog on Brother 270d stuck in up position
I finally figured this out. The feed dog switch in the back was not hitting anything when I moved it back and forth. There is a screw on the underside of the machine that I tightened. It seemed to do the trick. Thanks.
Posted on Jan 15, 2009
  • 323 Answers
SOURCE: My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
Posted on May 16, 2009
chrismyers67
  • 53 Answers
SOURCE: I have a brother XL 5130 should I have either a
This machine does not have a feed dog drop, but it does include a feed dog cover that covers them so you can do free motion. The cover is a little piece of black plastic that kind of resembles this: 3d18346.png
Here is the link to the manual,
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000062/xl513052325340ug01enesfr.pdf
Let me know if you need more help, Chris
Posted on Jun 12, 2010
  • 109 Answers
SOURCE: Brother XL-5130 machine...cannot get it to darn or
You probably do not have lever to put the feed dogs down. That's why you have a cover. To free style embroider or darn you don't need a foot but the presser foot has to be down and as you run the machine, YOU will be doing the stitching by moving your fabric back and forth. This is usually done with a wooden embroidery hoop so that your fabric stays taught. I have done it on jeans without a hoop. Hope this helps.
Posted on Aug 23, 2010
  • 1788 Answers
SOURCE: Just purchased a Singer Inspiration
Take it back where you bought and have them show you how to do it. Or, see is you can tighten the needle plate yourself, If, you can't call Singer (1-800-4singer) and find out where the authorized service center is. You should not have to pay anything with it being new. Good luck
Posted on Oct 24, 2010
Feed Dogs
when the feed dogs are in the up position the sewing machine
will sew
but when the feed dogs are down postion it will darn
try the feed dog lever again if you can move the feed dog lever and
the feed dogs respond going up and down then you know that
the feed dogs are working and are not broke
but if they do not respond then they need to be checked to see what's
wrong with them
Oct 23, 2012 | Sewing Machines
Does XL5340 have drop feed dog lever?
Look on the back of the machine for a slide-type switch near the sewing area.
Aug 22, 2012 | Brother XL-5340 Mechanical Sewing Machine
Brother CS6000i feed dogs issue :(.
sounds like something may have broke or come loose,, I'd take the machine to someone else to have it checked to see what the poping sound was
Mar 09, 2012 | Brother CS6000i Computerized Sewing...
Feeder dogs will not advance the material
Are your dog feeds lowered perhaps? Check by turning the flywheel towards you with the pressure foot up and no fabric, can you see the feed dogs coming up above the needle plate? If this is happening, then check stitch length setting, should be 2.5 or 3 for a normal stitch.
If the feed dogs are not coming up, then they are either lowered, this is usually engaged/diseanged with a dial, slide or knob on the base of the machine, behind the free arm or sometimes inside the bobbin area. Reengage, then turn the machine through a couple of stitches as they don't just pop up again.
Nov 01, 2011 | Brother XL-5130 Mechanical Sewing Machine
Can you tell me how to lower the feed dogs on my Brother XR-52 for free motion sewing?
You use your feed dog cover, it is a plastic cover you put over your feed dogs. Your manual will show you, if you do not have your manual go to www.brother-usa.com and select support, home sewing & embroidery group, then select your manual, you can then download your manual for free
Apr 23, 2011 | Brother XL-5130 Mechanical Sewing Machine
I have a brother XL 5130 should I have either a plate or lever to drop the feed dogs? I also misplaced my manual can you send me the English ssection thanks Barbara
Jun 11, 2010 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 machine...cannot get it to darn or embroidery work. I covered feed dogs with the plastic cover but cannot find a lever to put down the feet. With presser foot lever down (no feet and not...
May 18, 2010 | Brother XL-5130 Mechanical Sewing Machine
Feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Aug 26, 2009 | Brother SE-270D Computerized Sewing...
Feed dogs are down
You might have the machine on a setting that does not use the feed dog. Check your stitch setting and see if that helps.
Dec 12, 2008 | Brother XL-2610
Spring not connected behind bobbin casing
It is most likely the feed dog return spring. A cam lifts the feed dogs up and the spring pulls them back down. It hooks to the feed dogs bracket and goes straight down to the machine frame, there should be a small hook or post for it. You may be able to sew slowly without it attached.
good luck!
Nov 24, 2008 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
126 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
