Question about AEG 24 in. Favorit 50730W Free-standing Dishwasher
Leak prevention system
I have an Electrolux ESL 6225 dishwasher & the machine sometimes makes an audible warning of 3 beeps which means the leak prevention system has been triggered. The machine is not leaking. How can I eliminate this problem or reset the system?
  • 1314 Answers
SOURCE: Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Posted on Feb 12, 2008
yalmer
  • 549 Answers
SOURCE: anti flood system has been
Copy and paste to your browser.
www.serviceforce.co.uk/pdfs/U27431.pdf
It will download to your computer and these are the instructions.
Posted on Apr 22, 2008
SOURCE: AEG 60830 Leak prevention system
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
Posted on Feb 18, 2009
  • 44 Answers
SOURCE: Water is not draining away
Best off to call a certified repair company such as Sears.
Posted on Oct 16, 2010
SOURCE: My AEG Favorit Sensorlogic Turbodry dishwasher is
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Posted on Mar 25, 2011
Hi, my dishwasher is stuck draining and issuing the three beeps 'anti-flood' error with no sign of a leak? Is it possible to re set this?
you need to remove the bottom plate and clean up any water. it most likely means there is a leak in the gasket around the door and it tripped the flood sensor. the only way to reset it, is to deal with any water and dry it up and then power down and power up the washer.
More importantly I would look for leaks. Bad hoses or possible rubber that dried out and cracked. Maybe someone spilled water and it got on the sensor too. Either way , water is what causes that sensor to activate.
Sep 02, 2015 | Dishwashers
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Electrolux esl 6226 not working beeping sound and light flashing
Hello Eamonn, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 12, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
What does the shower and bar smybol mean on my ESL 63010 Dishwasher please?
I've been dealing w/electrolux for over 2 years on a dishwasher problem. Technician have tried all that they know & the dishes still come out dirtier than when they go in. I've been using it as a drying rack. Kinda exspesive drying rack. Electrolux won't stand behind their product either.They are offering me a 60% discount on a new Elextrolux dishwasher! Are they kidding?
Apr 01, 2011 | Electrolux Dishwashers
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
All lights are flashing... what does that mean?
Remove the two screws that hold your kickplate on the bottom of the dishwasher (1 on either side) and look at the LED panel, it will tell you what is wrong. More thank likely, it will say a leak code. If that is the case, you'd have to pull out the dishwasher, flip on it's back, and remove the 3 phillips screws that hold the drip pan in place. Dry up the water, and it will likely work again, howver, you should install the Electrolux leak kit to prevent this from reoccuring. Part number is 154769101
Dec 25, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux ESL 6225
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
AEG 24 in. Favorit 50730W Free-standing Dishwasher Logo
299 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
