Question about Home Security
Need Security System Pro 5100 manual
I have replaced the nine volt battery but it continues to alarm and has become deprogrammed.
4 Suggested Answers
  • 4090 Answers
SOURCE: Vista 15 pmt security system. I'm not sure how to
If you attempt to disconnect the battery the alarm will go off and you may not be able to reset it. there is a specic code to be set before any maintenance can be done. These codes are all different otherwise there would be no security!
Any alarm company would be willing to change your battery and if its a monitored alarm they might also want to take on your monitoring. Call an alarm or security company in your area for assistance
Posted on Aug 17, 2009
  • 78 Answers
SOURCE: I replaced the battery on
Did you run sensor test(drop down cover enter you code pess test button then done button. let run 5 min. close cover press status button If that fixes great. If not, you need multi meter. remove battery put metter on leeds coming off panel. You should see voltage there at least equal to the battery. If not then you may see the the red wire for battery has a lump in it about 1" long that is a fuse. remove wire from panel and meter for resistance/continuity/ohms what ever you want to call it. if there is no resistance or an open ckt then replace that wire.if you see resistance in wire then you have a bad panel. GL.
Posted on Apr 23, 2011
  • 910 Answers
SOURCE: When I try to arm
What Zone are you trying to set the sensor on as it shouldn't be used on Zone 1 or 2 as detailed in the manual at the link below.
http://www.skylinkhome.com/docs/manuals/security/AS433E_install_20060816.pdf
Posted on Jul 23, 2011
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
2001 audi a6 key fob wont unlock doors
You either have a dead battery in the remote or the key has become deprogrammed. Try replacing the battery, if that doesn't work you may have to have it reprogrammed at the dealer.
Feb 12, 2014 | Audi Cars & Trucks
Adui key fob wont unlock/lock car
Kidde # 1276 chirps indicating low battery. Battery replaced and chirping continues. Why?
Don't know for sure, but if your smoke detector is more than 5 years old, than you have to purchase new one (that's their average lifetime). Take a look on amazon: Amazon com smoke alarm. I hope I have helped. Cheers
Aug 08, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Accidentally reversed the battery cables on my 98 honda accord 4cyl. 2.3l. I already replaced the main 100 amp fuse, replaced the main relay, replaced battery , and had alternator tested and its good. it...
If your car came with the Prestige Alarm unit, there is a possibility that the alarm box got deprogrammed or burned, and left the anti-theft activated. Use the Valet Switch to deactivate the alarm permanently, and see if the car starts. For some reason unknown to me, it takes a couple of cycles of crank/ take the ignition switch off, crank again for the Valet Switch to work. In my 98 Accord, this micro-switch is installed in the left front kicker panel, but there is no guarantee that it will be in the same place in you accord, since it is a dealer installed option
Jun 12, 2011 | 1998 Honda Accord
Battery went dead after nine years.! I replaced battery and drove for a couple days ...Now battery light came on ...alternator bad?.... help!
Yes ,the alternator,have it checked,or check it yourself with a volt meter connected to the battery,with everything on,ac on high blower,and headlights on,it should be charging 13.65 volts to 14.25 volts,if it is any lower than this,replace the alternator,thank you ,and please rate,if this was helpful,at all.
Jul 19, 2010 | 1998 Lincoln Continental
How to reprogram Karr alarm in Scion tc?
dealer only or wouldnt be any good as an alarm if any tom **** or harry can do it ,Try disconnecting the battery and holding the leads together for a minute then reconnect the battery
Aug 12, 2009 | 2006 Scion tC
Bypass alarm flashing on a Powerware 9125 UPS
it is possible the bypass alarm is flashing because the i/p and o/p are not within range to switch without a break.
they need to be nearly equal in volts and freq so when the ups switches the ups o/p is continuous.
you should be able to check this with your ups software.
Mar 26, 2009 | Computers & Internet
12"volfenhag subwoofers
use a 9volt battery, touch both wires to the battery connections, if the speaker jumps upward and away from the magnet, the wire on the positive (+) terminal of the nine volt is positive (Red), if the speaker jumps inward towards the magnet, then the wire on the positive (+) terminal of the nine volt is negative (Black). CAUTION: only TAP the wires to the nine volt terminals briefly, if you hold them on there it may damage the speakers voice coils, (or other parts.) best of luck!
Oct 25, 2008 | Volfenhag ZX-4712 Car Subwoofer
Home Security Logo
211 people viewed this question
Top Home Security Experts
Are you a Home Security Expert? Answer questions, earn points and help others
