Question about Electrical Supplies
My professional power station ps1000 will not charge in the house but will in the car
2 Suggested Answers
egbj2007
  • 3 Answers
SOURCE: I have a Professional Power Station PS1000 that
my professional power station ps1000 will not charge in the house but will in the car why
Posted on Dec 11, 2012
I have a stanley fat max professional power station that wont charge when i plug it in .Left charging over night but didnt do any good. What is wrong with it.
Hello, Al -
Even rechargeable batteries are no longer rechargeable. I suggest you purchase a replacement battery. From a number of reviews I have found about the power station, the rechargeable battery life is about 2 years, maximum.
Best wishes
Dec 18, 2017 | Max Audio Players & Recorders
My paradigm ps1000 speaker does not turn on what's wrong ?
Check all fuses and plugs, if they are OK your power supply may have failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 19, 2011 | Paradigm PS1000 Speaker
The rain gauge will not record the rain fall. It displays 0.00 on everything except last month. I now have it in the house have checked the batteries(they were fine) have cleaned it (it wasn't dirty) and...
You say 'the batteries were fine'. How did you check? With my weather station, the main station will not display the outside temperature when the battery gets to a certain point. The display on the weather station is fine, but it doesn't have enough power to pick up the data from the outside sensor, despite not being very far away. Replace both sets of batteries to be certain.
Nov 22, 2017 | Honeywell Professional Weather Station...
Have a Professional Power station PS1000 chharger. Light indicates charged but voltage meter when pressed does not move. emergency light comes on but weak.
I have the same problem with my ps1000. I turned on the light and plugged the charger. it lit up the charging led. after 2min the reverser clamp led with a light buzzing came on. I am going to keep charging it but keep checking it for over heating. dont want it blowing up in my face. lol
Aug 08, 2010 | Measuring Tools & Sensors
Witch way does the teflon side of the seal face the impeller side or motor on a waterway spa pump
the rubber seals around the housing. the teflon goes against the graphite fitting so there is a seal, but it is a mechanical seal.
David
May 16, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
My Hayward pump is leaking.
is the pump leaking from the lid if so you may have an obstruction **** as dirt leaves or debree if the pump is leaking where the motor meets the wet end of the pump then you need to replace the ps1000 seal not sure if ps1000 will work on hayward but when you go to buy one. tell the pool store employee that you need a ps seal for an hayward.
Apr 28, 2009 | Hayward Pool & Spa
Trying to switch out my base unit on the 9120 I am trying to trouble shoot a loud screeching sound that happens when I hang the phone up cant get my head set to switch to the new base
The loud screeching is probably due to the headset mic volume being too loud, or the campatability setting on the base station is in the wrong position for your phone.
To register a new earpiece to a base station, simply put the headpiece on the charging dock and leave it there while you disconnect the power, wait about 20 seconds and then reconnect the power. All the lights on the base should flash a couple of times and then the green charging light will start fashing as normal. The headset should then be registered.
Aug 20, 2008 | GN Netcom GN 9120 Professional Headset
Electrical Supplies Logo
192 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
