Frigidaire frs24zrh filter cup is overflowing. replaced the filter and purchased a new filter cup & housing, but the housing is not set up exactly as original, so i just used the new cup and o-ring...still leaking
SOURCE: water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
SOURCE: replacement of water filter housing
I finally got mine out, using an oven mitt. I guess I just was weak.
SOURCE: GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
