Sony bravia kdl - 46s504 tv shuts off after 13 seconds, no error code
Replaced inverter and power boards. Still has this problem.
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
Posted on Jan 05, 2009
  • 53 Answers
SOURCE: 40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Posted on Jan 22, 2010
  • 1684 Answers
SOURCE: 13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 13, 2010
SOURCE: My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Posted on Jul 14, 2010
  • 8457 Answers
SOURCE: I have the Bravia 40" KDL 40V3000. When I turn
Power supply board is dead 90% of the times.When the power turn on LED power light indication flashes.5% might be the Tuner board,that the board taking in the incomming broscasting cable plug into this board.5% might have both death boards,power supply board and the Tuner board.Problems,u have never indication LCD inverter board,backlight problems.U shouldn't have replaced the LCD inverter backlight board,bacause backlight are dead,have flashes of picture few sec.than dies,still have hear sound.
Posted on Aug 05, 2010
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony Bravia KDL 32BX300 Error codes
Five blinks denotes an IRK error. To detect damaged components and to troubleshoot this error, you must have sound in electronics.
May 21, 2013 | Sony Bravia KDL-32BX300 32" 1366 x 768...
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
Sony KDL-40s4100 flashes and error code of 2 after about 7 seconds, then nothing. The backlight was on for about 2 seconds.
Have the same tv with the same problem. Changed the power board - no help. Next I changed the inverter board - no help. Only thing left is the LCD screen. I junked mine out. Hope I helped you out even if it wasn't what you wanted to hear.
Dec 10, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Tv turns off after playing 15-20 minutes, then it will shut down more often. the timer/pic. off button flashes six times. thank You.
6 times power/ standby light blink error shows problem of back light inverter board in your Sony KDL-37M4000 tv as per mentioned in related service manual.
Check back light inverter board to fix the issue.
Thanks.
Jun 17, 2010 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Wont turn on
It is back light inverter board failure error. Check back light inverter board in TV.
Aug 08, 2009 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Apr 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Dec 28, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Four blinking red lights.
the error code is triggered by the inverter fuses, which blow when the inverter fails
Dec 05, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
