Question about Top Knobs M826 Door Pull
Emtek entrance door knob will not open - Top Knobs M826 Door Pull
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: I have an emtek key in knob lock and wont disasemble
The locks are tricky, they have special tools to make it easier, I'm not saying you can't do it, but if you can't get the knob apart, I don't know if you can get the pins in the tumbler right. Usually a pin hole in the side of the knob will release the keyset, then the ring in the back will release the tumbler, the cap on the top will release the pins, and I mean release, hang on to them, cause they fly! Put the tumbler back in without the pins, put the new key in, make sure it is right, drop the pins in one at a time, first the bottoms, they should all be the same size, then the tops will be according to the cut in the key. Or is it the other way around, drop in the springs, put the cover on, if it works the first time, you will be very lucky. Hope this helps.
Posted on Mar 20, 2010
Knob does not come out all the way into the door frame for closure. why?
Most common reason for this is the hole its going into on the frame is either not deep enough and/or the hole and strike plate/larch are not properly aligned (i.e. its hitting the side of the wood etc.,).
Mar 01, 2015 | Ultra Satin Chrome Exterior Entrance Key...
Tip
Sagging handle on Emtek door lock set
My front door has a very nice Emtek cast bronze door latch set with a deadbolt. a few months ago the inside handle started sagging so I looked on line and did not see what I thought the problem might be. At any rate it turned out to be super simple so I thought I would post the fix hear with pics.
I simply removed the interior side of the lock set and found that the spring that holds the lever handle up had slipped off its stop. I simply removed the lock washer that holds it in place, re positioned the spring behind the stop and it works great now.
I am not sure how the spring slipped off, as it is quite tight but I am sure it had something to do with two ten year old boys going in and out constantly ;-)
http://i.fixya.netwrite_tip-dpvo4qigktl0w3wlwtq4dsz2-3-1.jpg
on Sep 10, 2015 | Miscellaneous
I need an emtek spanner
if you have access to a code reader plug it in wherever your plug is under dash;if you cant access it or have no idea what im talking about find an autozone near you thell scan it for free n tell you the codes look em up for you.
Jul 29, 2013 | Cars & Trucks
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
Mar 20, 2010 | Top Knobs M826 Door Pull
I have an emtek exterior door lock, that is stuck in the locked position. I can only open it with a key, and not even the inside unlock mechanism will permanently unlock it. I took it apart as much as i...
If the opening is on the side, it probably comes off by pushing a small tool (pick or large paper clip) into the hole while turning the key. When you feel the pin move, pull on the knob and it should come off.
Nov 19, 2009 | Top Knobs M826 Door Pull
Problems changing a doorknob
If there are no visable screws on the inside of the door than there is a cover plate that can be removed by prying it off with a small screwdriver revealing the screws. Please remember to rate my answer
Jun 30, 2009 | Kwikset Professional Door Lock...
Can't take apart an EMTEK entry set
Hope I can help! I have worked with Emtek before and some of the front plates are secured with screws from the the other side of the door. You may want to check if this is the case. if so remove the screws so you can remove the exterior plate. Best of luck. Hope this works!
Nov 18, 2008 | Hardware & Accessories
Top Knobs M826 Door Pull Logo
52 people viewed this question
Top Top Knobs Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Top Knobs Hardware and Accessory Expert? Answer questions, earn points and help others
