Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer makes a loud sound during agitation
Sounds like a belt is slipping. Also seems like there is water left under the drum.
SOURCE: washer spin problem
Ok so your having problems with the washer spin problem. Well there mightbe a sound that it is making like a jumpoing sound. Well when you here that open it and you might notice that all the clothes are on one side. That means that you put too much clothes in the washer, and it can't handle it. So open it and take out some clothes and restart it. I hope i helped you problem's. Thank you for taking your time to read my article.
Posted on Feb 12, 2007
  • 3 Answers
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at  http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Posted on Jul 05, 2008
stephanos18
  • 144 Answers
SOURCE: WHIRLPOOL LXR6232EQ0 WILL NOT SPIN OR AGITATE
Hey there, it sounds like you need a new motor coupling this is the weak link between the motor and the gearbox. This can be and easy job if your good at pulling things apart. You need to remove the main drive motor as this part is a link (It has two white, three pronged plastic bits and one round rubber joiner) on the motor shaft and g/box shart. If you don't know how to get into the machine I can explain that also, everything unclips you just need to know where. cheers
Posted on Mar 24, 2009
  • 97 Answers
SOURCE: basket doesnt agitate, and makes a really loud sound
Hello Friend, Your solution is very simple. I beleive that you need to replace the motor coupler. It's easy to replace the motor coupler on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, just lay the washer on it's back. At this point you will see the water pump, motor, and transmission. Remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Now, remove the two screws that hold the two spring clips attached to motor. Unplug all the wires etc. and then snap the metal clips off motor. Lift motor straight up, it should slide right off. Now you will see the motor coupler. Half of the coupler is on the transmission shaft and the other half is on the motor shaft. There is a rubber center connector ring that connects the two together. Just remove the old coupler pieces by prying under them with slotted screwdriver and replace with new ones. Re-assymble the washer and the problem you are encountering should be solved. Happy to help, Tim. And please don't forget to give me your rating for my help.
Posted on Jun 27, 2009
skrbin
  • 121 Answers
SOURCE: when washer gets to high spin, makes a loud sound & drum stops.
probably belt was spill out or broken
Posted on Jul 05, 2009
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Agitator seems to slip and not constantly move during wash cycle
no it is not suppose to slip it sounds like the agitator dogs need replacing it is quiet easy to repair and not expensive it only cost me $8 and took twenty minutes to do when I replaced the ones on my washer
Dec 28, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a GE washer WJRE5500GWW. It makes a loud grinding sound during agitation and spin cycle.the spin seem a bit slow but it pumps out the water just fine.
its your drum bearings going there just about worn out,,not a cheep job to fix sorry,,,soon it will start leaking water from the drum drive shaft!!!
Jul 15, 2010 | Washing Machines
Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Kenmore:Noise; agitator not working; drum full of water...HELP!
Sounds like you have a broken motor coupler, check the tutorial at www.shop.washermd.com dave
Jan 12, 2009 | Kenmore 15944 Top Load Washer
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
