Question about Craftsman Snow Blower / Snowblower Bottom Cover :
Can not start snow blower
Will only run when i use starting fluid ,then it dies out
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Todays gas is horrible for gumming up after a few months. You need to clean the carburetor.
This description is for many 4 cycle engines.. it Might help The jet in the Carb is gummed up. Take that 1/2" bolt off the bottom of the Bowl..That IS the Jet. Many times the Bowl will just hold in place with the Bolt out.. make sure the three holes are clear. 2 are close to the head of this bolt and you should have a 3rd real small hole where the threads end. Screw it back in...see what happens
Posted on Dec 11, 2012
  • tony renzetti Dec 12, 2012
    Thanks for advise,I removed all the old gas and cleaned the jets.put some fresh gas in and it started on the firts pull.
  • wadingriver
    wadingriver Dec 12, 2012
    glad you are good to go when the snow falls. Run the Blower totally dry next Spring. Although the residual still might clog the Jets.
Won't start. Even using electric start function.
try a spritz of Starter Fluid, if it tries to start then you know you need to clean the carburetor that was probably ruined by ETHANOL gas
Nov 21, 2015 | Poulan Pro 24" 2Stage Snow Blower Electric...
Snow blower runs well then dies to a rough idle
Sounds like it has dirt or water in the carb and is slowing down the fuel flow and starving the engine of fuel.
Feb 16, 2015 | Poulan Pro 27" 2Stage Snow Blower Electric...
Runs for 10 minutes and stops
When running is the idle smooth or up and down?
Is the chock operating, or adjusted after the motor gets warm?
Is the carburetor needle adjusted after the engine idles to warm as it should be to be set correctly.
Are you blowing snow when it dies or at idle?
Feb 01, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Engin wont stay running after it starts
How long does it run? A few seconds or minutes? Sounds fuel related. Generally rebuilding or replacing the carburetor will fix it if it starts and dies after a few seconds. If it runs for a few minutes then we need to look at something else for the issue
Jan 15, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Will not start even withew gas
Try a spray of starting fluid into the carb. If it fires you know you have good spark. If it did not fire replace your spark plug. If it still won't fire point and condensor need to be replaced. If it did fire spray the starting fluid in the carb a few more times to pull the old fuel through the fuel line til the new gas gets through the carb and then it should run. Some machines have a fuel shut off valve make sure it is open.
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
I have a Toro S620 snow blower, I push the primer bulb and it starts right up then dies. If I keep pushing the primer bulb continualy it will keep running but the moment I quit it dies.
The carburetor bowl needs to be taken off and most likely the float and needle need replacing. When you prime the carb, this is shooting gas straight to the carb instead of traveling though the jets. This is a very easy task, but I know if you're using a snow blower you need it quick. The kit is about $5 and be sure to take your machines info with you.
Dec 30, 2010 | Toro Snow Blower Scraper For S200 s620 New...
Engine Dies When Auger Engaged
Bough Sno-Tek 24 in. Two-Stage Electric Start Gas Snow Blower - under 2 feet of snow and engine dies when Auger is enagaged! Hope someone can help.
Jan 28, 2009 | Garden
Craftsman Snow Blower / Snowblower Bottom Cover : Logo
97 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
