Question about HP Photosmart D7360 All-In-One InkJet Printer
Hp photosmart D7360 cancels my prints before they even start or in the middle.
I have ran all the test under settings and everything comes out perfect. When I put in my card it starts to print, then cancels printing. It starting doing it in the middle of printing. How can I fix this???
rosener
  • 103 Answers
SOURCE: HP Photosmart C3100 print problems
Hope this helps; Try Printer Self Test feature by placing a paper on tray or bypass. Start from off position press Enter button or equivalent and hold down for 3 seconds and press the power button on. Do not release yet the Enter button until it initializes for self test printing. We'll see if it prints correctly or the colors will be printed completely. Proceed to uninstall everything or reinstalling if found print test is correct.
Best regards,
Rosener Guyano
Posted on Feb 05, 2008
SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Posted on Aug 04, 2008
hsanfor
  • 71 Answers
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Posted on Jun 20, 2009
joecoolvette
  • 5660 Answers
SOURCE: How do you open HP Photosmart D7360 Printer case?
Hold the bottom base of the printer with one hand, grasp the top cover under the HP logo, and pull upward with the other hand.
Posted on Aug 12, 2009
SOURCE: HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Posted on Oct 13, 2009
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printing is blobby rather than sharp
That my friend is your cartriges,i had the same problem.
Sep 28, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 not seen by PC, despite driver, s/w loaded
Not a solution per se - just a diagnosis. I have decided that the USB out port on the printer is bad - and after wasting time just trying to crack the case, will just use this as a photo printer "offline." It prints beautifully directly from media inserted into any of its onboard slots. I will just have to save things as .jpgs or picture formats to print from this printer. HP didn't have the part available, anyway. I called and inquired.
Jan 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Can't print on home network
Well an unisall and reinstall of the printer drivers on the network would definately solve your concern.If you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
Jan 20, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
try cleaning the cartridge contacts with alcohol and cotton swab.
Jan 16, 2008 | HP Photosmart D7360 All-In-One InkJet...
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
