Question about Sanyo SW-1150T Washing Machine
SW-13DV1 cycle doesn't finish E1 error displays
Actual model is SW-13DV1. Machine stops mid-wash. No buttons work to clear cycle, E1 error displays. Unplugging has no effect.
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Error E1 samsung washing machine model TORNADO 7.0KG WA90B
    E1: Water Supply Error
    -Display Shows 'E1'
    -Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
    -To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
    -The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
    Keep me posted!
    Nov 01, 2012 | Washing Machines
    My washing machine has stopped washing in every cycle, it keeps saying 'test' on the lcd display panel. When I do turn it on to do the 'test' it just spins for a while then stops and...
    Hi Justine from retired Englishman in SW France,
    Here are the instructions to clear the 'test' depending on the date code (possibly on the manufacturers panel at the back):-
    Date code 39 March 2005
    Press start/cancel until ALL LEDS are lit
    Press both start/cancel AND on/off together until 'dOFF' is displayed
    Date code 39 March 2005 to date code 42 June 2005
    Press the cancel button and the machine should return to norma
    l
    Date code 43 July 2005 onwards
    Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Sep 04, 2011 | Hotpoint Washing Machines
    F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
    Close the washer and press the START/PAUSE/Cancelbutton to remove error displayed and restart the cycle. If it doesn't work, it means thatthe valve at the water entry needs to be replaced..
    Hope this helps..
    Jun 10, 2011 | Siemens Washing Machines
    Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
    Hope this helps..
    Jun 10, 2011 | Siemens WFXD8400UC Front Load Washer
    I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
    WATER DRAIN ERROR - Display shows 5E.
    5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
    Dec 11, 2010 | Samsung Washing Machines
    My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
    oe means drain error (outlet error)
    Poss causes:
    drain hose kinked,
    filter blocked,
    pump impellor blocked.
    Hope that Helped
    Please Rate Me
    George
    Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
    Zanussi jet system 1200
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
    Rate me pl.....if helped.
    Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
    Sanyo SW-1150T Washing Machine Logo
    24 people viewed this question
    Top Sanyo Washing Machines Experts
    Are you a Sanyo Washing Machine Expert? Answer questions, earn points and help others
