Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Fisher paykel dishwasher dd603 won"t turn on.
Won't turn on
  • Fisher and P... Master
  • 3,247 Answers
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Posted on Mar 19, 2013
gary1121
  • 332 Answers
SOURCE: I need to repalce the elctrical supply cord and water supply line to my Fisher & Paykel DD603 dishwasher, but I'm unsure as to how to remove the terminal box cover. Could you please help? Thanks.
THIS IS SIMALAR TO THE BOSCH UNIT, IF THERE IS NO BOTTOM COVER TO REMOVE YOU NEED TO TAKE THE SCREWS OUT OR THE TOP INSIDE THAT HOLD IT TO THE COUNTER TOP, PULL THE UNIT OUT SLOWLY, TURN OFF THE WATER SUPPLY SHOULD COME OFF THE HOT SIDE OF YOUR FEED LINE TO THE FAUCET UNDER THE KIT SINK, THE WATER SUPPLY IS ON THE LEFT LOOKING AT IT AND THE ELECTRIC IS ON THE RIGHT IF YOU CAN PULL IT OUT ABOUT 8 INCHES YOU CAN GET TO BOTH CONNECTIONS TO BE ABLE TO DISCONNET PULL OUT ALL THE WAY GET BEHIND IT AND CHANGE WHAT EVER YOU NEED TO
Posted on May 29, 2009
  • 784 Answers
SOURCE: my dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Posted on Nov 01, 2009
  • 3247 Answers
SOURCE: fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Posted on Dec 13, 2009
  • 19 Answers
SOURCE: Hi, I need a parts and service manual for a dd603
http://kitchen.manualsonline.com/manuals/mfg/fisher_paykel/dd603h.html
Posted on Mar 02, 2010
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
The green light on top of the amp won't turn on
ground your amp properly make sure its bare metal
Mar 06, 2013 | Car Audio & Video
I have a 1999 Gilera Runner 180FXR, New bat 12V 9 amps. Starter turns and spins pinion gear but won't engage starter ring. If it does it turns ver slow or won't turn engine over. In manual it
Yep, not enough amps to engage the starter clutch, and when ti does engage, not enough amps to turn the engine. You need a 12 amp battery.
Nov 17, 2012 | Motorcycles
Loud knocking
Sort of sounds like the timing belt broke-- if you have one
The valves may have hit the pistons & that is why it won't turn over
I don't know any of that is true & won't wish it on anyone,but
it is a place to start
Sep 13, 2012 | 2001 Saab 9-3
My PS2 won't turn on
It's dying. Buy another one off ebay for cheap.
Jun 30, 2012 | Sony PlayStation 2 (PS2) Console
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
98 chevy cavalier turns over but won't start
i know industry jargon can be confusing, but lets try this. if it turns over but won't start, it could be your ''ignition module'' that sits on top of the vave cover on the motor or it might be the fuel pump or filter. make sure when you crank the engine that the key is all the way turned or it may not always make a proper contact to activate the ignition module. iv'e seen this before & had to change the ignition switch & all worked ok after that. i would need to know engine lt size to give you more details on the matter. please get back to me.
Nov 19, 2011 | 1998 Chevrolet Cavalier
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
May 18, 2011 | 2005 Kymco Venox 250
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
502 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
