Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Leaking water sub-zero bi-36u
SOURCE: leaking sub zero 650
I fixed my leaking problem by pulling out the vegetable drawer and checking the condensation drain hose. Sure enough, it was clogged and the condensation had nowhere to go but move out toward the front of the fridge, down the left side and onto the floor. Once that drain hose was cleared (with a bendable straw), no more leak!
Posted on May 08, 2008
SOURCE: Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Posted on Nov 24, 2008
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Posted on Nov 29, 2008
  • 56 Answers
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
  • 97 Answers
SOURCE: My sub zero refrigerator is holding the set
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Posted on Jul 29, 2009
Freezer light in subzero model BI-36U won't go on
subzero are bad about the light switches going bad.... on most there are 2 switches one is for the freezer fan and the other is for the light... how to tell the difference is when u push the fan switch in the fzr fan will come.. the other one is for the light..... hope this helps.... ken
Oct 09, 2014 | Sub-Zero Refrigerators
Why is Water leaking out of the bottom outside corner of my sub zero fridge
I would guess your drain is clogged and leaking. Without a model number I can't instruct you where to look and correct this issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 12, 2014 | Sub-Zero Refrigerators
Where is the water condensation hose located in the Subzero BI-36U
Under each evaporator are drain troughs for each section, the tubes are connected to the trough and the drain into a pan under the unit, below the freezer section. I hope this answers your question.
Aug 02, 2014 | Refrigerators
Sub zero leaks water
You need to replace that water line, except it's not on top on a 632. And those weren't available in 1994. Do you maybe have a 590?
Jun 26, 2014 | Sub-Zero 632 / S
Where is the water filter on a sub zero model 690 and how do I change it
This model did not have a filter, if one was installed it would be under the unit. The black kick plate is held on by 2 screws, it would be tucked under the unit because its a job to roll out the unit. When I change them at work its always under the refer door side.
Good Luck
You can purchase any in-line filter you wish to use for this model. Only the new BI models sold today have filter.
Aug 17, 2011 | Sub-Zero 690 Side by Side Refrigerator
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
2,004 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
