I have a Hitachi 52" that has a yellow half circle and a half circle blinking blue line in the upper left hand corner of my tv..do u know if this is a bulb going out or what it could be?
    New Friend:
    Problem Solver:
  • 6 Answers
I thing your lens on the light need cleaning because it is a rear projection tv.
Posted on Dec 11, 2012
SOURCE: Blue Streak
I had the same problem w/ the same TV about 6 months ago. You need a new optical engine. Hopefully you are still under warranty. Once that was replaced, the tv looks great.
Posted on Dec 27, 2007
  • 58 Answers
SOURCE: Blue ghost image on the top left hand corner of my Hitachi 50V500A.
You have a defective light engine and you do not have to be under warranty for Hitachi to replace this part. We just went through this and here's what you need to do. Call Hitachi's customer relations department at 800-654-7013 and tell them that you have a defective light engine. They will act like they've never heard of this problem but they have. They will give you the names of some certified dealers in your area to call. Once a tech comes out and confirms that it's the light engine, call Hitachi back and they will send a brand new light engine to the dealer and Hitachi will cover the cost of the part (cost $1500).
Here is the deal, if you're under warranty, Hitachi will cover the part and the install. If you're not under warranty, all you pay is the install. Our install cost $400. Others on this site have paid $200. Do not let anyone tell you that you have to pay for the light engine part...you do not. Hitachi has not recalled this part but they are replacing it for free. Also, deal only with Hitachi customer realations number that I listed. Good Luck!
Posted on Feb 14, 2008
talon1973
  • 17 Answers
SOURCE: Blue spots on a hitachi 50vg825
You will need a new optic block assembley. This has been a common problem found in all brands of LCD projection type television sets.
Cause for this is fine dust and particles gets "cooked" onto special lenses and even on individual lcd panels. I haven't found a way to clean each optic peices back to original. I usually find the colored filters in most of them had changed to a brownish, hence blocking that color from getting through, leaving a pink, or bluish spot like hue, or even in some cases a starfeild like patern.
Only thing can be done is to search the Internet for a new or refurbished optic block assembly to your make and model.
In the shop I work for, I've seen literally hundreds of these sets, all brand who makes LCD projections, develop this kind of problem. I've exchanged optic blocks on everyone I've gotten since 2001 - 2002 and so far never seen one comming back with same problem twice.
If you are good with following instructions, then it maybe cheaper for you to purchase a service manual with all the parts blow up, access to "Service Man Mode" with all adjustment codes, then purchasing a new or rebuilt optic block assembly... (Some manufacturers will send you a different optic block assembly of wich you must enter the Service Man Mode (SSM), for making proper adjustments per advice from their techs).
Changing one can be a real chore, so it maybe in your favor to higher a competent tech who can do the job right at a good price. If you can't find a personal tech, then shop will be next in line, however it maybe a little expensive.
Posted on Jan 09, 2009
tvtek
  • 1284 Answers
SOURCE: Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Posted on Nov 26, 2009
  • 1267 Answers
SOURCE: have a 55 inch hitachi plasma tv. The picture
Seems as if your high voltage power supply went kaput. This happens sometimes see the complaint
at: http://hitachi-home-electronics.pissedconsumer.com/hitachi-55hds69-plasma-tv-20100417178696.html
See: http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/55HDS69.aspx for a list of parts and you can see if it is worth fixing
Posted on Dec 01, 2010
Picture and color distortion
I am having the same problem hopefully some one answers us.
It's a Blue Convergence issue but how to fix it I am still waiting.
Apr 13, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Mar 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Hitachi 53SBX10B
It sounds like the lamp is failing.
Jan 06, 2018 | Televison & Video
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Picture Problems
the unit needs new conv ic's. they are part no stk392-180 need two.Also you might need 2 2.7 ohm resistors with minimal soldering skills,you should be able to repair unit
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
