Question about Zenith P50W28B 50 in. Plasma Television
My zenith 50in. tv keeps saying check external input link status.what does that mean?
What does it mean when no signal and check external input link status?
  • Zenith Master
  • 8,617 Answers
The main board needs replacement. you should be able to get the replacement main board from www.tvcircuitboards.com
Posted on Dec 11, 2012
Im using coaxial cords to hook up a Samsung DVD player to my westinghouse TV and it keep saying no signal
"no signal" typically means that you have hooked your player to one input, but have selected a different input on your TV. Best is to use an HDMI cable, not coaxial.
Aug 08, 2016 | Samsung Televison & Video
Power light on no video or sound on 50in. flat screen tv
I think somehow that the input is changed. locate the input button on your remote and toggle between all the input to find your lost signal
Oct 13, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
TV Says 'NO SIGNAL' but plays CD via player ok. What are the possible causes of a NO SIGNAL on a black background?
No signal means that some external source (aerial, HDMI input, AV input) isn't providing a signal.
Your TV plays a CD okay because that is built-in.
Try connecting an aerial feed and tuning the TV.
Sep 08, 2014 | Televison & Video
What is monitor status no input signal mean?
It means that for the selected input (many models have multiple selectable inputs), no video signal is present. Check to be sure that the cable(s) are connected correctly and that you have the proper input source selected for the monitor.
Sep 02, 2014 | Computers & Internet
Why would the tv say no signal
If you have selected an external input and there is no device connected and turned on, the TV will give this indication. Select another input (TV, HDMI, Video), or connect and turn on an external device. When there is a signal to the selected input, the "no signal" indication will go away, assuming the input is working correctly. I hope this helps.
May 09, 2014 | Televison & Video
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
No signal means you have a different input enabled somewhere...like TV/HDMI/VGA ...you are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Jul 09, 2017 | Acer AL1917 19 inch LCD Monitor
My tv has no signal and it has check external input link status
Relace the main board. You can get repacement main boards from www.tvcircuitboards.com
Dec 11, 2012 | Televison & Video
The screen is black and a little box that says no signal is moving around on the screen
Check your inputs. The no signal box means exactly that - there's no incoming signal for the TV to decode. So you've either disconnected a cable somewhere or turned off your input device.
Try changing the inputs on the TV (this will be a button saying input or A/V)
Try changing the channels
Check that your cables are correctly connected and that whatever you are trying to use (dvd player, PS3, etc) is turned on.
Check that your TV is tuned to the corresponding input it is plugged in to (if you plugged your DVD player into HDMI input 8, tune your TV to input 8)
Hope this helps.
May 11, 2011 | Sanyo Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
What does it mean when a viewsonic says no signal
No input signal from your computer or external device is being received. Could be loose connection or connected device not powered up or asleep. If laptop connected you need to toggle external screen <Fn><F8> toggles through displays.
Feb 08, 2010 | ViewSonic VT2430 LCD TV
Zenith P50W28B 50 in. Plasma Television Logo
366 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
