Question about Honeywell Icp Heil Tempstar Furnace Spark Ignitor Assembly 1173829 P8e-ce19 Comfort Maker
I replace limit switch on my furnace heater with a wrong one and my thermostat sparked. My heater won't turn on now. What can I do?
    Genius:
  • Honeywell Master
  • 1,033 Answers
Csn you check the 5 amp fuse on the Furnace control board to see if its blown?
Posted on Dec 11, 2012
  • 20 more comments
  • Bertha Martin Dec 11, 2012
    Is the fuse inside the control board because I don't see it. This is the board type that is in the heater: 50E47-140
  • Robert Dec 11, 2012
    Yes the fuse looks like aautomotive tupe fuse which is 3-5 amps. It is possible the thermostat is bad since it sparked. You can takenthencover off the thermostat and take the red, white and green wire jump them togethur and see if the furnace starts.
  • Bertha Martin Dec 14, 2012
    Haven't had a chance to do what you suggested but will do it on the weekend
  • Bertha Martin Dec 15, 2012
    we turned off the gas on the heater, do you know if when we try to jump start the thermostat if the pilot will also turn on?
  • Robert Dec 15, 2012
    Is this a direct spark ignition or spark to pilot ignition system?
    I don't know which one it is. We did try the jump start on the thermostat and the pilot does come on but the furnace won't turn on.
    Can you take a pic of the pilot assembly, it is crucial to know what type it is because they operate a bit differant.
    It is possible the ignition module is defective, if the ignition assembly is not sparking. If it is sparking then the ignition assembly could be defective
    I attached a picture, I hope I took a picture of the correct area.
    This is the gas valve, do you see a control board onthe furnace where a bunch of wires attach to?
    Is this the correct one? The board type number is: 50E47-140
    Yes that is the one thank you. Donthe burners light at all?
    No they don't.
    Ok sounds like you will need a new ignition module. If the module was not fused, the spark probably damaged the module
    Ok thank you so much for your help
    Is the module the box?
    No problem. Yes it is the box where all the wires attach
  • Bertha Martin Dec 16, 2012
    Does it make any difference if I get a box with the same model number but with the letter "D" instead of "E"?
  • Robert Dec 16, 2012
    No, the only differance it that the D is a universal model
  • Bertha Martin Dec 22, 2012
    I replaced the module but the burners still don't light up.
  • Robert Dec 22, 2012
    You will need a multimeter to check for voltage at the gas valve. There should be 24 volts
  • RJ Systems (Retired) Dec 17, 2013
    The older mercury thermostats always spark inside the bulb when opening the circuit, or to say, when the heat turns off. Replacing the hi limit switch on the heat exchanger should not affect that. Can you give us pictures of the stat and limit?
Tip
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
on Dec 30, 2009 | Heating & Cooling
Lennox furnace won't start
Check the circuit board to see if the little 1 amp car fuse is blown, if it is replace it, if not, check to make sure the furnace is on and the door switch is engaged. if that doesn't work call a proffesional to come diagnose the furnace.
Mar 01, 2013 | Heating & Cooling
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
Outside heating unit runs all the time
Feb 19, 2010 | Heating & Cooling
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Jan 30, 2010 | Heating & Cooling
Goodman model 135-5 furnace fan and induce motor run all time even with thermostat off. Theermostat and wire were replace
Is there a thermal Fan/Limit switch in this furnace? If so you may need to tweak the low range setting so it can turn off the blower.
Nov 04, 2009 | Goodman GMS90703BXA Heater
Honeywell Icp Heil Tempstar Furnace Spark Ignitor Assembly 1173829 P8e-ce19 Comfort Maker Logo
221 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
