Question about Hobart Welding Tools
Where can i find a repalcement motor for my hobart handler 180, 217 778
  • Dennis Johnson Dec 11, 2012
    I tested the motot and it has conductivity across the leads so the motor is bad. Hobart part number is the 217 778 off the owners manual. can't see to find it anywhere on the internet if any one has a link for itt that would be great. thanks
3 Suggested Answers
  • 3 Answers
SOURCE: hobart handler 135 wire feeds for about a two feet
This happens to me all the time. Wear and tear has taken its toll and everything has to be maintained for it to work. Most likely the welding tip is worn and should be replaced. Lincoln electric tips work well and I will replace mine several times during the day. Also check your tension and make sure the wire will uncoil freely from the spool. You can remove the tip and make sure the wire will feed without it. If not, your liner may be worn out. Also a welding Jell will help keep the tip from cloging. It will still happen, but hopefully not on your first weld of the day.
Posted on Feb 04, 2011
luis_david
  • 407 Answers
SOURCE: drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
Posted on Nov 21, 2011
My motor on my hobart handler 135 is not working to make the wheels roll to feed wire. I disconnected it at the connectors and tested it and was not getting any readings on my meter as if it was not g
Make sure the trigger switch is applying power to the motor. If there is no reading when you checked for OHMS then the motor is open. You'll have to get a new one.
Jan 13, 2014 | Hobart Handler 140 Mig Welder
Drive motor for hobart 125
Nov 21, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Have Hobart 140 Handler, The motor won't run to feed the wire, even whith out wire. gas will come on when trigger depressed.Where can I find parts to fix?
You need to look at the wiring diagram to see what parts could be causing the problem. I had a 120 that did the same thing and it was the bridge rectifier that was bad. I unhooked my motor and hooked it to my battery charger to see if it was good.Hope this helps. I will see if I can find a diagram to look at and check back later to see if you have fixed the problem.
Aug 07, 2010 | Hobart Handler 140 Mig Welder
I need to know ware i can by a motor wire feeder
Hobarts website has a service feature. They also have technicians that will help you identify the correct part number/s to ensure that you are ordering the motor you need. You can get the parts straight from them.
Apr 02, 2010 | Hobart Handler 125 Ez
Need to try and find a wire feed motor for Hobart 120 Handler.Mine is smoking.I think its a 1997. Thanks
go to praxair ,air gas s j smith or any welding shop they can get it for you,
Mar 16, 2010 | Hobart Handler 125 Ez
I have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
Jan 05, 2010 | Hobart Handler 140 Mig Welder
My Hobart Handler 120 needs a .045 wire drive wheel. Where can one be purchased?
Locate your locale Hobart welding distributer, or contact hobart, the are nice people and will give you all the avice you need.
Dec 26, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
198 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
