Question about Skil DWOS 7.5 AMP RECIPROCATING SAW VS VIBRATION 114-9200-01
Skil saw stops I bump it it starts then it stops I bump it it starts
It's a reciprocating saw and it just stops If I bump the side it runs for a short time The brushes seem to be long enough and riding on the end OK there are two grooves on the armature are they suppose to be there?
    Champion:
  • 304 Answers
The two groves could be caused by the auto stop pin in the brushes but I would also check the brushes are not getting stuck in the brush holders.
Posted on Dec 17, 2012
How do I troubleshoot my Bosch 1632VS reciprocatings saw?
brushes possibly wore out . search for bosch website for parts . Google Bosch parts
Oct 15, 2016 | Bosch Panther 060 1632 834 Vs...
Does 6509-31 sawzall have thermal overloads
No the 6509 does not have a thermal overload.
Start by checking the brushes & brush springs then test the switch & cord
It is possible you burnt the armature out but brushes, switch, or cord is more likely.
Mar 07, 2015 | MILWAUKEE ELECTRIC TOOL CORP Milwaukee...
How do I remove blade that's broken off in a Skil 9216 reciprocating saw?
Turn the release as far as it will go, then tap on something blade down till it emerges.
Aug 03, 2014 | Skil 9216-01 9.0 Amp Variable Speed...
I have a dw307 reciprocating saw that runs for 10 seconds and stops. Any ideas?
Check the set of tangs that the battery contacts. That is actually the bottom of the switch. The tangs can become spread apart or can also overheat and break off causing you to not get full battery contact. Common problem on these tools.
Jul 15, 2012 | Dewalt DW307 Reciprocating Saw
I am having trouble inserting the blade properly
You press the lever forward all the way, insert the blade, and release. If the holder is getting worn it can be replaced as one complete assembly. Here is the user manual link. It shows how to use the holder.
Skil 9225 manual
The part number for the holder assembly is 2610938752. It is less then $10 and is held on with an allen screw so it's easy to change.
Jul 15, 2012 | Skil 9225-01 9.5 Amp Orbital Reciprocating...
Sawzall runs but wont reciprocate
Seems like the wheel and gear are not hooked up, reopen it and check the reciprocating arm connection is where i would start
Apr 05, 2012 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Feb 05, 2012 | Saws
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
Skil DWOS 7.5 AMP RECIPROCATING SAW VS VIBRATION 114-9200-01 Logo
173 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
