Question about BIC America Bic Venturi Vk-12 12 Inch 1000-watt Kevlar Series Front-firing
Vk-12 blows fuses has anyone had this problem?
I've just fitted An rb30 engine into a vk commodore I need a complete wiring diagram or a verbal breakdown of the electricals an how they should be wired up I've searched an searched the web been thru...
I would be going to the local library and finding a manual for a VL. Or you could buy a Haines manual.Then check the differences between the VL and VK .
Jan 31, 2018 | Cars & Trucks
Cop fuse keep blowing on my 2000 lincoln ls
I just got a lincoln ls v8 and fuse #12 cop's is missing what is this fuse for thank you
Mar 02, 2012 | 2000 Lincoln LS
Hello I have a 1994 Honda GL1500 Goldwing. The 5 amp fuse for backup blows every time I install a new one. The backup fuse holds memory for the cb, the radio, the clock. The backup fuse is located on...
I agree it could be the radio. try unplugging the radio then install a new fuse. If the fuse doesn't blow then you've found the problem. If the fuse blows then try unplugging 1 component at a time until the fuse no longer blows. Don't plug in the components after you've unplugged them until you find the issue. The problem with the clock could be related to the direct short - then again maybe not, but finding the short first should be your main priority. If you have any relays associated with those components then that could also cause your problem as the relay may have the short occurring inside.
Good luck!!
Nov 25, 2010 | Honda GL 1500 SE Gold Wing Motorcycles
Ive got a 1992 ford escort and the radio, interior light, cigarette lighter and clock fuse keeps blowing. Ive taken out all of them seperately and it seems that the problem isnt caused by one thing and i...
According to my info, each of these items has its own fuse. ARe you saying 1 fuse keeps blowing?
If a fuse blows, it means a wire is shorted to ground or that an item the fuse is protecting, is bad.
A good way to diagnose this, is to place a 12 volt buzzer or bulb in place of the fuse that keeps blowing. This will give you a light or buzz noise. Then, you disconnect times or wire connectors until the noise stops or the light goes out. Then investiagte that circuit.
report back
Aug 11, 2009 | 1992 Ford Escort 4 Door
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
BIC America Bic Venturi Vk-12 12 Inch 1000-watt Kevlar Series Front-firing Logo
65 people viewed this question
Top BIC America Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a BIC America Audio Player and Recorder Expert? Answer questions, earn points and help others
