Question about Amana ACS3350AS Gas Kitchen Range
How do you remove the control panel on amana gas range model number asc3350as0
SOURCE: Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Posted on Dec 25, 2007
Basti
  • 1447 Answers
SOURCE: I would like to replace
chances are you can
call this number 877-232-6771 for information about replacement parts and accessories
Posted on Jun 04, 2008
  • 126 Answers
SOURCE: I cannot seem to get
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
Posted on Jan 02, 2009
  • 323 Answers
SOURCE: bad electronic contral panel on Amana gas range
On the Amana: Several Ebay stores carry panels like this. Problem is, once you open electronics they usually are hard to send back.
The stove is ten years old. You'll likely spend more than it is worth finding the right part and repairing it. It might be a good time to consider buying a new stove and selling this one for parts or scrap.
Posted on May 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have an Amana gas stove and oven. Model -
Replace the glow bar ignitor.
Posted on Jul 06, 2010
Add tension to loose oven door amana gas model args7650ss
Hello. You will need to replace the door hinge assemblies. The part numbers are as follows:
Right hand hinge 31715202
Left hand hinge 31715201
I hope this helps you.
Aug 14, 2015 | Amana Kitchen Ranges
I would like to replace the oven door on my Amana gas range model ARG7302WW, is it possible?
Yes, its possible.
Remove the door from the range.
Place the door on a flat surface with the front facing down.
Remove screws held the inner door panel.
Remove the inner door panel and you should get access to the door handle screws.
- Here are the break down diagrams for the Amana range Model ARG7302LL
Jun 04, 2008 | Amana Kitchen Ranges
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
Nov 25, 2011 | Amana ACS3350AS Gas Kitchen Range
Amana ARGS7650SS Gas oven takes a long time to heat up, and then, in the middle of baking, the digital control panel goes blank and the oven goes off. Eventually, the panel will begin flashing and, with...
This is Amana's fault and is common on several oven models and types.
Your timer and clock control board has some loose solder joints and they can be re-attached by any competent electrical repair shop with soldering skills. TV shops can often be convinced to do this for you for a nominal fee.
Nov 07, 2010 | Amana ARGS7650SS Gas Kitchen Range
Our Amana AGDS902 Gas Kitchen Range is beeping and flashing an F7 error code. We have found solutions for other Amana ranges online, but none of them seem to be for our exact range type. We can stop the...
AMANA – Range/Stove/Oven Fault Codes
Glass link Electronic Range Control (ERC)
F7=Shorted touch panel Verify glass to adapter board connection good, if so, replace glass panel.
Dec 02, 2017 | Amana AGDS902 Gas Kitchen Range
Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Dec 01, 2008 | Amana ARGS7650SS Gas Kitchen Range
Model ACS3350 oven stops heating up mid cycle
Does your range ever get very very hot on the exterior, mostly by the control panels?
Nov 15, 2008 | Amana ACS3350 Gas Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
138 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
