Question about Sony Handycam HDR-HC7 Mini DV Digital Camcorder
Tape housing wont go down into my sony HDR HC7E. Handycam. Says reattach the power source and I have. Still wont go down.
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Hi,  If possible please would you
Here you go just click on manual and Print if you would like.
http://camcorders.about.com/gi/dynamic/offsite.htm?zi=1/XJ/Ya&sdn=camcorders&cdn=gadgets&tm=3&gps=134_154_1127_593&f=00&tt=14&bt=1&bts=0&zu=http%3A//esupport.sony.com/perl/select-system.pl%3FDIRECTOR%3DDOCS
Good Lick and Please Rate FixYa!
Posted on Jan 18, 2009
  • 4234 Answers
SOURCE: Blown Sony HDR-HC7E fuse or board?
There are internal fuses yes, but they are surface mounted ones and not a DIY repair. There are protection diodes internally as well. If the adapter was not the correct one, it is possible that it popped the diodes and fuse.
You can buy the service manual from Sony directly for a cost.
Hope this helps,
Dan
Posted on Apr 30, 2010
welcomejee
  • 10594 Answers
SOURCE: can't close tape door on
This problem occurs when tape mechanism got problem and tape mechanism replacement is solution.
Tape mechanism replacement in this camcorder is job of qualified tech because novice can cause more damage.
Let me know if you need tape mechanism part number info.
Thanks.
Posted on Jun 23, 2011
Rick Riggins
  • 1812 Answers
SOURCE: the tape door wont close
Error code 32:11 indicates a problem in the cameras tape transport sestem.This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Aug 21, 2011
Hi I've connected a firewire cable between the handycam and my new iMac. iMovie/iMac doesn't recognise the connection. Are there settings on the Handycam that need to be made for transfer to the iMac?
No need to change any settings it will auto connected.Check your cable may be its faulty. Try other think to attached your iMC.If still not working then You Firwire driver not instal.
Oct 28, 2010 | Sony Handycam HDR-HC7E DV Digital...
Cassette deck will not close
Deck assy will need to be repaired or replaced. The only other thing that you can try (before taking it somewhere) is to unplug the camcorder from any type of power source, leave it unplugged for about 10 minutes, and try again. Also, make sure that your tape is not damaged in any way. www.austintelstarservices.com
Sep 01, 2010 | Sony Handycam HDR-HC3 HDV Digital...
Hope this helps,
Dan
Apr 30, 2010 | Sony Handycam HDR-HC7E DV Digital...
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Error code C:32:20
My best solution, is to pull all power sources form the camera for 24 hours. If this does not work, then take the small screws surrounding the Tape housing, in order to try and get the tape out. Best of luck dude ;)
Feb 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Cant record
C32 error codes are usually cassette or tape transport related. Can you eject the tape? Try inserting a new tape to see if the fault is with the tape itself.
If this doesn't work, I suggest that you take your camera to a service centre.
Sep 10, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam HDR-HC7 Mini DV Digital Camcorder Logo
43 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
