Question about HP Officejet 4500 Wireless All-in-One Printer
My mac doesnt recognize the printer
I used the usb cable and the disk nothing works. I see my printer under printers but it doesn't respond to the print command
  • HP Master
  • 3,606 Answers
Hello try to download the latest software from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=3919448#N197
Please uninstall the old software before you install the new.
Good luck
Posted on Dec 15, 2012
2 Suggested Answers
  • 4 Answers
SOURCE: how do i connect my wireless printer to the network
Well first off you should have a usb cable that would initially start you off it has to be hooked up via usb first then u can disconnect the usb & use it wireless. U should also have a driver disk & a manual that would help u as well. Also U can go to your computer on desk top & click there & then go to the device manager click on printer or & see if there is a connection from there if not there will be an exclamation point & then u can go to the top of page & click on scan for hardware changes till u see can see the connection if not uninstall and reinstall
Posted on Nov 02, 2012
My computer doesn't recognize my printer
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Dec 08, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Usb device not recognised lexmark s405, tried all advice listed in google pages except petrol & lighter.
Have you tried using another USB cable? You can also try plugging the printer in to a different USB port in your computer.
Also, try to plug in the printer to a different computer, if it works then there's a problem with the USB port of your computer. If it still doesn't recognize the printer, it could be the USB cable that's causing the problem or the USB port of your printer. If that's the case and your printer is still under warranty, contact our technical support team to have the printer replaced. You can find the contact number at our site: www.lexmark.com.
Jul 05, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Blinking lights
Power off printer, remove power plug from printer, remove usb cable from printer, pull out paper and check for jams, check toner cartridge, clean area underneath the toner cartridge head, uninstall printer from windows control panel, reboot computer, plug-in printer with a different working usb cable, plug in power to printer, power on printer, reinstall printer driver. All in those steps exactly. If that doesn't work I would say you have a bad printer on your hands.
Nov 16, 2011 | Dell 1110 Laser Printer
Hi, i have some problems with my ML-2010R, it doesn't respond to anything from the computer. when i press ON it makes the usual noises,eating and preparing for printing , but when i try to send a file...
try to use a new USB cable maybe the problem is on the cable this transfers the data from your PC to the Printer this is a common issue for printers. Or update your printer driver.
Sep 02, 2011 | Samsung ML 2010 Laser Printer
My 6530 works OK as a copier but not as a printer or as a scanner. I suspect that the USB interface is defective.
It is could be a software related problem. Software called drivers are needed to run the printer. The drivers for your printer can be found on the CD disk that came with your printer. They can also be downloaded from the manufactures website, click their downloads/support button and select your model of printer. Download and install the drivers for your specific model of printer and for your specific version of Windows.
Take care!
damnor01
Aug 13, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
The hard disk inside it doesn't responds to the controller - hardware failure, the disk has failed.
Nothing can fix that, your unit is truly dead and you need a new one.
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Hp printer is not working
I understand that this printer is a usb printer. All you should have to do is start windows and then plug the printer into your computer's usb port. Windows should recognize the printer and install it.
If this doesn't work you should unplug the usb cable and install the printer software. After you install the software it should recognize the printer when you plug the cable back in. If not you may even have to reboot before it does see the printer.
You can also try going to control panel, printers and faxes and click on add printer. Follow the instructions in the window that pops up and you should come to a window that will tell you to insert the software disk. Insert the disk in your CD drive and click ok. It should walk you through the rest.
Jul 12, 2009 | Office Equipment & Supplies
Canon MP780 issue on Mac OS/X
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
Sep 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet 4500 Wireless All-in-One Printer Logo
217 people viewed this question
Seeker5211
Seeker5211
