How Do i Fix a Loose DC Port on a 2010 Sony Vaio?
At first it was just lose all i had to do was jiggle the Power Cable in the Port a little and it would charge and now no matter what i do i cant get it to receive the charge i dont have much money so i need a cheap way to fix it please help :|
    Novelist:
    Champion:
  • 233 Answers
Please refer to the following article for solving this question:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Posted on Dec 12, 2012
    Guru:
  • 571 Answers
Do you still have a warranty for that computer? You should a get free servicing or perhaps a replacement for it. Or have you tried using a different power cable?
Posted on Dec 11, 2012
  • John Mack Dec 12, 2012
    Warranty Ran out last month havnt gotten around to renewing it.....i bought a new charger last week and its still not working
  • Carlo Adrian Canon
    Carlo Adrian Canon Dec 12, 2012
    It's a problem in your motherboard and you need it get fixed. Anyone with soldering skills can fix that. If you do, then you can do it yourself. (seriously). It probably pulled/pushed the traces off the main board and will require superglue, solder, and maybe a bit of fine wire, to fix. The biggest obstacle will be the dissassembly, and proper reassembly of the laptop case. It'll take a while, but once fixed, should return your laptop to 100% functionality
jameskewlnc
  • 7 Answers
SOURCE: REGARDING A SONY VAIO PCG-TR3 LAPTOP
Follow this link -> http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCG-TR3F&region_id=1
That is the link for all drivers for your pc. Some software unrelated to drivers or fuctionality cannot be downloaded from this site. Contact Sony for more details on getting replacement software. However, the link I provided will help get your pc running with all drivers.
Posted on Dec 31, 2008
  • 3940 Answers
SOURCE: Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Posted on Apr 26, 2009
  • 26 Answers
SOURCE: Can I power my laptop through th usb port
I know you've either fixed your problem, or thrown the laptop out(still a "fix") but for posterity, and for anyone with a similar problem...
There are two answers, depending on your laptop.
First, NO, there is currently no way to charge your laptop battery by putting power into the usb port.
There ARE commercial external batteries. sadly, they will connect to your failing power-socket.(see http://www.laptop-battery.org/Power/External-Batteries/ENB003L.html)
If your laptop has a external battery charging dock, for spare batteries.... you could go that route.
you'd probably still want to follow the last suggestion.
GET IT FIXED!
Seriously... anyone with fairly good soldering skills can probably fix that powerjack. It probably pulled/pushed the traces off the main board and will require superglue, solder, and maybe a bit of fine wire, to fix. The biggest obstacle will be the dissassembly, and proper reassembly of the laptop case. It'll take a while, but once fixed, should return your laptop to 100% functionality.
I have saved 3-4 laptops with this technique. One, I even swapped the power jack to a more common size. This was to allow the use of a non-proprietary power brick(the original had fried itself).
Posted on Jun 18, 2009
  • 1335 Answers
SOURCE: Loose power connection on sony vaio PCG 7V1M
I'm assuming the laptop is out of warrantee.
It sounds like the power adapter jack is broken. To replace this you have to take the laptop apart down to the motherboard, unsolder the jack, solder on the replacement and reassemble the laptop. This is not something a novice should attempt.
Check with your laptop repair shops. The replacement/repair should be under $100.
Posted on Mar 02, 2010
  • 2567 Answers
SOURCE: the ac power plug was
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 19, 2010
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
Sep 28, 2010 | Acer Computers & Internet
My netbook is plugged in to the wall and the charge port but is not showing that its charging. why? and how do i fix it?
Sep 26, 2010 | ASUS Eee PC 1000HE Netbook
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
I have a problem with my DC In port. I have to finagle my cord in different directions to achieve a charging state. Do you think I need a new charger or is there an easy way to fix it
If the DC input port feels loose then thats the problem. If not then the cable might be damaged on the inside. Happens if the cable is rolled up and unrolled frequently :)
BD
Sep 06, 2010 | Sony VAIO VGN-FE670G Notebook
My sony vaio labtop doesnt charge any more unless i use my hand to support where the charger cable connects the labtop.
This must be a loose DC Port Issue. If the system is still under warranty, you can call Sony and they can repair it for you.
Apr 03, 2010 | Sony VAIO (PCWA-A200)
Power button is not working on my sony vaio fw21l
if the computer is still in warranty, call sony vaio tech support and they will send an onsite technician to repair the dc in port of the computer.. 888 476 6972 or 239 768 7669
Mar 22, 2010 | Sony Computers & Internet
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
Power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
Dec 22, 2009 | Sony VAIO FW Series VGNFW275JH
Internal fuse need replacing
Sorry, but i don't think there is fuse on motherboard.
More likely its a loose DC socket cable to motherboard or faulty AC adapter.
If Dc - ok, AC - ok, then its a faulty motherboard.
Mar 12, 2009 | Sony VAIO FR130 Notebook
DC port?
check adopter may be replace with any other laptop adopter....
May 04, 2008 | Sony VAIO GRX520 Notebook
Computers & Internet Logo
David Payne
David Payne
