Question about Dishwashers
Bosch SHE43C05UC/22 Dishwasher cycles take 3-4 hours to complete. After cycle is complete, dishes do not dry and interior is not very hot (opening the door immediately after a cycle used to put you a
I assume there is an issue with the heater or the control board. I ran the diagnostic program, and it ended with the "DELICATE/ECONO" light flashing. I cannot find the diagnostic codes for this model online. Anyone have a clue what this error code means? Thanks!!! Dishwasher is approx. 6-7 years old (came with the house). Have not yet checked the control board for bad solder points/burns.
  • 2 more comments
  • Nick Schill Dec 11, 2012
    By the way, this model does not have the LED readout for error codes like some of the other Bosch models...
  • Nick Schill Dec 12, 2012
    In doing some further reading, I found that some Bosch models have issues with the main control board burning out on one solder point in particular. Apparently adding a bead of solder to reconnect this circut fixes many issues, including the one I am currently experiencing. I'll probably give this a try and report back.
  • Nick Schill Jan 03, 2013
    Fixed. Took apart the door, removed the control unit, and there I found one bad solder point. Repaired the connection, reassembled the dishwasher, and it works as good as new!
  • Amie Krake Apr 23, 2013
    maybe that's my problem too!! mine has been running 3 or 4 hours and never stops. The repair guys said I needed a new internal heater for $450.
3 Suggested Answers
PapaSmurerf
  • 3 Answers
SOURCE: Bosch built in dishwasher shu4302uc
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
Posted on Mar 01, 2009
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
My dishes are no longer getting clean. Is it
Hello Sue. There are a few things you can do. let's begin by giving the interior of your dishwasher a good cleaning. To do this, with an empty dishwasher, toss in 2 cups of vinegar and then run your longest and hottest wash cycle. Repeat monthly.
Next, consider changing your detergent over to a product like Electrasol Dishwasher Detergent with Powerball Tabs. That product gets the highest marks from my customers.
Finally, always run the hot water into the sink until it reaches max. temp. before you start the dishwasher. Joe
Thanks for choosing Fixya!
Feb 16, 2011 | Bosch 24 in. SHE43C05UC Stainless Steel...
Dish soap is leaving a build up on the interior of the dishwasher
Hi. Run your hottest and longest cycle with no soap, no dishes and 2 cups of white vinegar. Also, run the hot water into the sink before starting the dishwasher. Once the sink water is as hot as it gets, then push the start on the dishwasher. J.
Jun 23, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes do not come clean and there is cloudiness on glasses
Hello and welcome to Fixya. There are several factors which influence how your Bosch perform's. Saying that brings me to a point I have to ask a few questions. 1) How long have you had the unit...when did you buy it ? 2) do the dishes always appear dry when the cycle completes ? 3) How long does the unit take to complete a "normal" wash cycle ? 4) Do you have adequate hot water going to the unit ? Let me know as much as possible and I should be able to help. I will watch for your response. Macmarkus :)
Jun 19, 2010 | Bosch SHU9915UC Dishwasher
Bosch dishwasher washes dishes but does dry completely
Heating element is probably not working. Open during dry cycle and feel if it's hot inside.
Nov 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
My bosch dishwasher will not dry the dishes
this dw to save energy works this way- the final rinse will reach a temp of 161 F . the dishes have to absorb this heat. when the cycle is complete the dishes become a heater in themselves radiating the heat they absorbed during the final 161 F heat. If you have any tupperware or plastic dishes in the unit they will not absorb heat therefore not radiate the 161 f temp need to dry all the dishes. try to avoid plastic items and they must always have jet dry. this is the european way of conserving energy. on the old ge or whirlpool they had electric element in the bottom that would bake the dishes dry ....not these..but they do save alot of energy.. it helps right after a cycle to crack the door open release all the steam from the unit
Dec 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
