Question about Frigidaire GLTF2940ES Front Load Washer
Washer spins but not fast enough to complete cycle and then shuts down
  • Official Brand Answer
  • 4,342 Answers
Hello GI GI - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Posted on Dec 12, 2012
  • 209 Answers
SOURCE: Washer won't stop spinning
i am a recently retired appliance engineer of 20 years, if the fault is not right after he has called then write to the manager of the company, if he is sole operator then write to him, explaining it like you said above, ask that the engineer stay and watch till the very end of the cycle as thats where the fault is, if he has already worked on the machine fetch them back? alternatively just ask a different engineer who knows what he is on about, to me this sounds like a circuit board problem either the timer or main pcb module, i presume this is a computer control washer with a digital display, hope this has helped you at least as to where to start, thank you.
Posted on Sep 13, 2007
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 125 Answers
SOURCE: Frigidaire GLTF1670ASO is cycling fast and not spinning
The motor controller is the most likly suspect as it controls the timer. I would check that first. Hope this helps
Posted on Feb 23, 2008
Krazytech
  • 725 Answers
SOURCE: 14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Posted on Aug 13, 2008
FitzOriginal
  • 842 Answers
SOURCE: washer spin cycle not working
As a blind guess, because I don't know this machine specifically, I would suggest it's more likely that the beep is a warning that the empty cycle has not managed to clear out all the water and so the spin cycle can't start. If this is the case, you probably have a filter on the drain pump somewhere (Either behind a door on the front at the bottom or under the machine, built into a bulge in a rubber hose near the empty pump). If there is a blockage here, or less likely, but still possible, if the empty pipe is blocked or obstructed, what you are describing is very likely. If it is the filter and you find it and clean it, you need to remember that these filters should be checked every month or so and cleaned.
Extend or reduce the checking periods depending on the debris you find in the filter and how much washing you do.
Posted on Mar 26, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
Frigidare (GLTF2940ESO) front load washer
Hi , I would like to know how to soak my whites. When it is on a full cycle Thank you
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Unit runs good through wash cycle then while in rinse and spin does not complete cycle. The machine starts doing a short spin, and then dial starts turning around without stopping.
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Feb 14, 2010 | Splendide 2100 Vented Washer-Dryer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Frigidaire GLTF2940ES Front Load Washer Logo
306 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
