Question about Memorex MHD8021 (2 GB) MP3 Player
Replace Battery Anyone know where to get a replacement battery for a Memorex MHD8021 MP3 Player? The current one is labeled: PL-423258 5C2702006 I100EL Or do you know the rated voltage so I can cobble up a substitute? I tried to Google the numbers but found nothing. Thanks.
5 Suggested Answers
  • 8596 Answers
SOURCE: charging the battery by the computer
Reformat the player - the instructions are in your user's manual, which can also be obtained off the internet at:
If that fails, get the firmware upgrade from the above-mentioned website
Posted on Jun 23, 2008
SOURCE: MP3 won't turn on
worked like a charm thanks
Posted on Sep 13, 2008
SOURCE: MP3 on off on off on off
Re-format it. plug it in and open my computer and right click on the mp3 player icon. the menu should have a "format" item. When you do this you will lose all the stuff you put in it but it will work. im not sure for how long. i just did it to mine last night.
Posted on Feb 24, 2009
  • 563 Answers
SOURCE: memorex video/mp3 player
I work for Memorex tech support. Our number is 800-919-3647.
You can't sync the Memorex player to iTunes, however, you can copy music from your iTunes library for use on your Memorex. First you must convert the music you want to copy into .mp3 format since iTunes uses a different format (AAC) as its default. Follow the instructions below to change the import settings in iTunes:
1. Choose Edit> Preferences, click the General tab, then click Import Settings.
2. Choose MP3 Encoder from the Import Using pop-up menu.
Once that's done, go back to your library and highlight the songs you want to convert. Once they're highlighted, right-mouse click and you'll see an option for Create MP3 version. This will not effect iTunes ability to play the music and if you have an iPod, it will not be effected either. After the conversion is finished, I suggest draging the songs you want for your Memorex player to a folder on your desktop. These .mp3 files can be copied onto your player and will play just fine.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
SOURCE: memorex touch mp3 player won't turn on
Mines doing this too - I reset by inserting a paperclip into the tiny reset hole on bottom right side of unit. Pain to have to do every time but it solves issue.
Posted on Jan 20, 2011
0 characters
1 Points
How would i know that it is getting charged
When charging, the battery indicator will cycle from the current battery level to full. Once the battery is fully charged, the indicator will stop cycling.
Typically it takes approx. 6 hours to charge the battery from empty to full. (MMP8565 2GB Digital Audio Player)
Support Home Page
Feb 03, 2014 | Memorex MP3 & Digital Media Players
Memorex MMP8002 my player will not start and does not recognize my computer connect it to my computer and restart any and from there not light nor my computer recognizes
does the player switch on at all? does it have a replacable battery, if not leave it plugged into a charger or computer for an hour to see if it puts any charge into it, and if the mp3 player has software then install it but only if you can get it to switch on. if nothing happens after doing all that then the player either has a faulty internal battery or the player itself is faulty.
Sep 01, 2011 | Memorex MMP8002 MP3 Player
Memorex touch mp3 player won't turn on
Mar 15, 2010 | Memorex MMP8567 MP3 Player
How to replace battery?
The clip on the back can be used as a turn-knob. Twist it off, and the back comes off. I doubt that anyone has the correct battery however. This player is one of the more problem-laden mp3 players out there, so a return of the item is not uncalled for.
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
My mp3 player will not charge, it says low battery, shutting down, then it goes black.
you have a bad battery, you can get one on ebay and then i can help you how to replace it
May 15, 2008 | Samsung YP-K3JAB MP3 Player
Sony NW-A1000 mp3 player
Page 83 explains how to get inside to replace the battery.
Good Luck.
Mar 17, 2008 | Sony NW-A1000 MP3 Player
How to replace battery for iRiver H10 MP3 Player
push the tab in on back of unit and slide battery off install new battery by sliding it back on and you will hear it click back into place
Jan 02, 2008 | iRiver H10 MP3 Player
Battery does not hold charge, does anyone know what kind of battery i need?
I have the same problem with my player. The manual says the following under the specs: Power Power Supply AC Adapter DC 5.0V, 2A Battery Lithium Polymer Battery Does this help? chichuck
Sep 08, 2007 | iRiver H320 MP3 Player
Cant get music to my mp3
  1. dowload this coverter tool.
  2. instal the program .
  3. open the program.
  4. select the music's that you want
  5. covert the music's that you want
  6. copy the music's to the mp3
  7. done , hear the music's
here is link to download the program :
please rated my solution...
Jan 13, 2007 | Memorex MHD8021 (2 GB) MP3 Player
Memorex MHD8021 (2 GB) MP3 Player Logo
Top Memorex MP3 & Digital Media Players Experts
Starnley Johnwells
Starnley Johnwells
Are you a Memorex MP3 and Digital Media Player Expert? Answer questions, earn points and help others
