Question about Maytag MBF2556KE (251 cu ft) Bottom Freezer Refrigerator
Fridge won't cool
The fridge is set to coldest but the fridge will cool to 36oF but then it won't come on again until the fridge gets to 48oF. Food is spoiling. I check for ice accumulation by taking the back off but nothing was wrong. Freezer is working just fine and so is the ice maker. Do I need to change out the thermostat or the control panel. I don't know which to buy.
  • Maytag Master
  • 4,654 Answers
The problem is either the fresh food section thermister or the=> W10196393 Damperfridge won't cool - 12_11_2012_5_08_54_am.jpg
If you would like a Service Manual for this model click here=> MBF2562HEB_Maytag_Refrigerator_Service_Manual When ready I will be here to answer your questions, Thanks Sea Breeze
Posted on Dec 11, 2012
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Posted on Mar 10, 2009
  • 17 Answers
SOURCE: Maytag FrenchDoor- fridge not cool
My friend you need a new circulation fan motor.
As you can see the diagram.
Your freezer do not need fan to be cold, but your refrigerator need a fan to deliver cool air into it.
Should you need more details please feel free to contact me at nguyen@ite.net
Posted on Jun 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. appliancepartsouteast@live.com
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Aug 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 17, 2009
Testimonial: "Thanks Sea Breeze! The photos do show a bit of a different arrangement than what is on the back of my fridge but I'll try what you suggested."
Cb 18 m
The cold control (thermostat) could be defective
May 30, 2013 | Whirlpool Refrigerators
Kenmore side by side refridgerator - freezer works very well, refridgerator not very cold, setting is on coldest set point.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 09, 2011 | Refrigerators
How long will it take to cool the refrigerator section down
Hello. For a fridge to fully cool down to operating temp takes up to 24 hours. J.
Jun 26, 2010 | Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Same problem
If after cleaning your condenser coils at the back or bottom, checking your cold control dial, checking your door gaskets for leaks using the dollar bill technique and looking for some resistence when pulling it out, checking for any obstructions, etc. nothing works, then you will need to have it service - most common problem is defrost timer - If your defrost doesn't cycle on, your evap coils will frost over excessively and you will not get sufficient cooling - you can usually rule this out by turning off your fridge and manually defrosting them with a blowdryer until they are frost free and running your fridge again for a few hours to 24 hours and check the temps again (during this time I'd set the dial to coldest) and monitor regularly, if your temps are getting colder and colder (fridge below 40F and freezer below 0F, then your problem is a faulty defrost timer - or one of its related components. (Remember to set your dial to what it was)
If not - then next common thing is door gaskets and finally a sealed system leak, maybe a tiny one and very slow progressing one,a lthough I would be inclined to think this is not it at this point, but if you get it serviced the first thing they should check is evap fan for proper operation, defrost timer, door seals and then compressor.
I hope this helps.
Aug 24, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Freezer work's excellent,, but fridge part is getting warmer every day now and will soon not be able to keep food cool. Have freezer set at D and E is coldest.... have frige set at 9 coldest setting but...
The freezer plates are the first to get the dwindling freon an dthat will remain the coldest. Find the leak and have it repaired (not just refilled or you will be here again in a few days!
JOAT
Jun 28, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Freezer cold, but Fridge only a little cool
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
Aug 28, 2008 | Haier HRF10 Top Freezer Refrigerator
Maytag MBF2556KE (251 cu ft) Bottom Freezer Refrigerator Logo
523 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
