Question about Monte Carlo Fans 5BR52 Ceiling Fan
Fan controls I want to control the fan from a wall control switch. Is there a combon control switch at Lowes (or other) that would control the 3-Speed fan and the light ? Is there any particular wiring required from the fan to the switch ?
    Genius:
  • Monte Carlo ... Master
  • 1,617 Answers
Yes,you need to have two hot wires to install a dual control. If you only have one and can't run another line you can use a wall remote,which will do both your fan/light using one hot wire. FYI ,I have one of these fans (display fan)I'm saleing for $250.00. 5BR52RBD
Posted on Jan 26, 2013
Honeywell Marston Ceiling Fan. Why has remote stopped turning the light off?
Dwayne, Try a new battery in remote, if that does not fix, replace your remote, replacements can be found at the larger hardware stores, eg. home depot, lowes,etc.
Apr 03, 2016 | Dryers
Had to disassemble a Hampton Bay ceiling fan to install a new light pull switch. Hung from a paperclip while fixing but it dropped and disconnected a number of wires. Rewired by my best guesses and now fan...
If you bought the switch from Lowes, most likely it's the wrong switch. Even if it looks the same on the outside, it could be different on the inside. As for the other wire, push it into the empty slot of the switch & see what happens. There has to be 4 wires in the switch. Black usually goes to L
Jan 04, 2015 | Hampton Bay Dryers
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
Problem with hunter ceiling fan 23272
The problem is with the remote receiver attached to the fan body. It is a small device that acts as a remote switch and this is cradled in a pocket inside the ceiling fan itself. If you are handy, you can replace this device yourself. I believe you need to purchase a new kit from Lowes that comes with a matched transmitter and receiver for fan control. Go to Lowes Lighting section for this product.
Jan 12, 2018 | Hunter Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
We want to replace our bathroom exhaust fan. We like the Harbor Breeze 'Rosemont' model at Lowes. It's a decorative combo fan/light unit. The unit is equipped with 2 13 watt (60 Watt incandesant...
It does not matter whether you turn on the switch or the switch is motion
activated, the light does not know who turns it on.
The switch must be designed for florescent.
What do you mean by proper base, you have a single gang wall box,
that's a box inside the wall, with the electric and a switch,
The gang could be single or hold 5 switches, which ever is installed.
Most all switches fill fit into any gang box.
Feb 08, 2010 | Dryers
Can i put a dimmer switch on a floor fan? i just bought an industrial-type floor fan, but i don't need that much air movement all the time, how could i wire up a dimmer or potentiometer so that i could...
A potentiometer would overheat because when you tell it to turn the power down, it basically just runs the extra power through a heating element, which will probably catch it on fire for something that large. A dimmer switch changes the voltage that goes in, and is generally meant for incandescent lights. If you wired a regular old dimmer switch up, the motor would probably sound weird, and the dimmer switch or motor would break, possibly starting a fire. It's illegal to use a regular light dimmer switch on anything but an incandescent light socket. However, you can easily find a controller that will work. Look for a fan speed controller or motor speed controller. Make sure it's rated for the correct voltage and has an amp rating not exceeded by the fan's rating. These look like a dimmer switch but are designed to deliver the power the motor needs. See link http://www.lowes.com/lowes/lkn?action=productDetail&productId=70801-539-SFSQ-FH-IV&lpage=none
Sep 17, 2009 | Global Product Resources Deco Breeze...
I tried to install a fan light control switch for
The reason the fan and light are running together is because the are both running on one power wire. The three wires you have in the wall are probably white black and bare copper. You need to run a four wire cable which has a white red black and bare copper in order for you to separate the light and fan and for the circuit to run properly. A DIY electrical book from lowes or the home depot would help you alot with your situation.
Jul 12, 2009 | Casablanca Fan (3845T) Brushed Nickel...
Control fan/light separately, with only two wires
They are available at Home Depot and Lowes. Hunter makes a wall mounter dimmer that will control the lights and fan speed separately. There is a receiving unit that mounts above the fan to the house wires on one side and the others connect to the fan.
The two hots you mentioned should be a black one and a blue one. The blue is for the lights; the black the fan. Ground everything you can to boxes, etc, if the house is only a two wire system without a ground.
I believe that remote wall switch and receiver runs close to $40.
Sirwriter
Apr 22, 2009 | Slider Lutron: Dual Fan Control / Light...
Monte Carlo Fans 5BR52 Ceiling Fan Logo
50 people viewed this question
Top Monte Carlo Fans Dryers Experts
Are you a Monte Carlo Fans Dryer Expert? Answer questions, earn points and help others
