Question about Cobra 29 LTD CB Radio
I have a cobra 29 lx le hooked to a francies 5.5 whip om my 2007 kw t 600 am getting anyenna warning both radio and antenna are new frustrated
    Top Expert:
  • 14,553 Answers
Have the SWR or match on the system checked, high match does not mean a bad antenna but can be a open or short in the system for the antenna.
Posted on Dec 12, 2012
Benimur
  • 6966 Answers
SOURCE: New Cobra 29 ltd
Appreciate the direct "Ask Me". If I may clear up your concern:
  • you have two CB radios, one is a Cobra 29LTD and the other?
  • both have received and both do not transmit;
  • you have two trucks, one with a Firecracker 1000 antenna, and the other?
In any case and initially, TX (transmit problems) could be caused by:
  • defective PTT/mic;
  • defective finals/drivers;
  • defective PL-259 connector/RG58 Cable;
  • antenna grounding/SWR;
  • other electronics internally
Please check the above. You may need an SWR meter, a watt meter and a DVM/VOM to perform the tests.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
  • 25 Answers
SOURCE: calibration problem
Changing the length of the mast more then likely made your antenna to short, and therefore impossible to tune.
Posted on Jul 14, 2009
  • 33 Answers
SOURCE: Cobra 29 LTD Bluetooth
You got your radio peaked? Most likely, however, the pot for the antenna warning indicator is VR6. I always check that after peaking a radio.
Posted on Jul 28, 2009
anymhz
  • 500 Answers
SOURCE: cobra 29 lx le radio
check the swr's
Posted on Feb 26, 2011
SOURCE: 29 lx le new 200
The "Antenna Warning" came up on my radio too, a new Cobra 29LX, but I found another bunch of people having the same problem. This alert that you are seeing is only supposed to basically come up on that screen if there antenna is not connected. There is a simple adjustment inside the radio. The component is a little potentiometer that has to be turned with a little tiny screw driver. You can do this yourself, just look for the PDF file online that explains and shows you how to do it in a few seconds.
Here you can finds the link to the PDF file right here.
http://www.thetruckersreport.com/truckingindustryforum/cb-radio-forum/147114-i-need-some-help-antenna-warning-5.html
This is an easy adjustment. I fixed my false warning in a few seconds.
Posted on Jun 17, 2012
How do i repair finals in cobra 29 lx
first of all are you sure its a bad antenna. I can key the mic with no antenna hooked up and nothing will happen the the finals but you may key it down with a brand new antenna and burn them also.Lokk and see how they are connected in the radio before you take it out and replace it the same way.You may want to replace your driver also.
Jun 13, 2014 | Cobra 29 Lx Full-featured Cb Radio
My muticolored faceplate won't light up on my cobra 29 lx le lcd
you can fix it but you have to take it one step at a time. go to www.cbtricks.com they have the manual you need.
Mar 26, 2013 | Cobra 29 Chrome LX/LE 40 Channel 4 Color...
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
CB Antenna Warning Light
Sounds like bad SWR. Check antenna ground. If mag mount, make sure mag and whe you put it is very clean. Check antenna where whip comes in to coil or base. Check pl259 with vom for continuity, open or shorts. This will probably solve the problem. DO NOT TRANSMIT WITH HIGH SWR. YOU CAN BURN OUT POWER TRANSISTOR. HOPE IT HELPS.
Tom
Oct 20, 2012 | Cobra 29 Lx Full-featured Cb Radio
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
29 lx le new 200 wilson antenna new coax and radio .we set the swr with a good meter at 1.2 and the radio says 3 or so and the message on the radio says cb antenna warning.and we doudle check the swr with...
what kind of meter? I would go by what is in the radio unless you are using an analyzer.
You may also be getting common mode current. take 6 to 8 inches of coax and make a tight coil about the same size as a spray paint can. Hold it together with electrical tape.
Use the meter in the LX LE to set the SWR then check with the other meter.
Nov 16, 2010 | Cobra 29 NW CB Radio
Cobra 29 LX LE antenna warning flashes when u key the mic and thiers no signal whats wrong
I am having the same problem with mine....I bought it new and it worked fine for a week.. How did you fix yours?
Oct 10, 2010 | Cobra GPS
Just bought a workman 3000 to 7500 watt cb antenna, ever heard of it?? Im going to hook it up at work monday, got a cobra 29 ltd + or - 30 watt output. 9' coax. the antenna has 8" of swr adjustment... for...
cobra 29 has a 12 watt final, doubt you will be doing 30 watts. 25 if your lucky. Use 18 feet of coax, you will get better broad band.
If the antenna comes with the whip in it already, its been tuned at the factory and you shouldn't change it yet.
If not, half way is okay. It still needs to be tuned on a meter. either the one in the radio or an inline.
Mar 06, 2010 | Cobra 29 LTD CB Radio
Calibration problem
Jul 01, 2009 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
107 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
