Question about Miele Professional PT7136 Little Giant Stainless Steel Laundry Dryer Stackable, 15Lb 6.5Kg 34Gal 4.6CF Honeycomb Drum, Hot/Cool Air, Moisture Control
How can we replace drum bearing of Miele PT7136 laundry dryer
4 Suggested Answers
  • 15 Answers
SOURCE: Miele T355 timer doesn't latch
Modern dryers use a step motor on the timer, as opposed to a fixed rate timer seen in older models. The timer advances using one of two different mechanisms, depending on the model. On most, the timer receives a signal from the thermostat that a predetermined temperature has been reached - on others it receives the signal from the moisture sensor (if so equipped).
Posted on Jul 20, 2009
  • 83 Answers
SOURCE: Miele T1515 electric dryer -
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Posted on Sep 17, 2010
Daniel S
  • 4323 Answers
SOURCE: How do I replace the drum belt on a miele 9820
Hi
To replace the drum belt on a miele dryer you can follow this procedure--
1. Remove the front panel.
2. Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
3. To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
4. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
5. Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
6. Remove the drum and belt from the cabinet.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 02, 2010
Miele Touch Tropic 9800. Why is it making a loud grinding noise?
Hi dear. Regarding your information,it's a dryer. Most likely it has bearing damaged or problem with drum drive system. There are several bearings on the dryer (one at the back- two on the front support, tension pulley etc...) I can advised to get it check by Miele. Thanks.
Apr 10, 2016 | Miele Washing Machines
Miele tumble dryer
Maybe time to replace it. How can it be too much detergent? That would have the effect of lubricating the seals!
Mar 04, 2014 | Dryers
Hi Gene, I have an Electrolux FEX831C30 stacked washer and dryer. the drum in the dryer has completely come loose and has dropped to the bottom of the dryer cabinet. there were two screws in the drum. what...
Good Morning Brian,
The reason the drum has fallen free from the rear is a defective rear drum bearing and that drum bearing that has sheared itself off of the bearing support.to repair that dryer ya would need to replace the bearing kit its part number 5303281153 and would be in stock at your local applince parts store or online at searspartsdirect.com, repairclinic.com, apdepot.com, partselect.com, or apwagner.com
Before replacing the drum the drum bearing you should also inspect the heat element since when the bearing shears off its not that uncommon for the drum to fall onto the heater shroud and also break the heat element
While this Youtube video i have included the link to shows how to replace the drum bearing in a full siz e free standing (not stacked laundry center) dryer the process of how to replace the rear drum beaqring is exactly the same and that video should help ya http://www.youtube.com/user/RepairClinic?v=67hOqSFnX8g&feature=pyv&ad=9033434261&kw=drum%20bearing
Good luck,i hope ya find it very simple to replace that bearing,
GENE
Jan 31, 2012 | Washing Machines
Miele t 4839c adjust the load
The drum is overloaded (too much laundry), or there is a problem with the moisture sensor not registering the moisture content of the laundry correctly.
Jan 23, 2012 | Miele Dryers
We've got a Maytag MDE6000AYQ dryer that we love. It started squeaking two loads ago. It would squeak off and on during the cycle. This next load seemed to squeak worse, so I'm worried to use it any...
The squeak is most likely from the drum support rollers or the drum bearing. If it's the rollers, they're fairly easy to replace and often a drop of lubricant will solve the problem. This is just one supplier of such parts:
http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drum+Bearings+and+Felt+Drum+Seals/default.aspx
Jun 21, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
Jul 20, 2009 | Miele Dryers
Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Mar 10, 2008 | Kenmore 98702 Stacked Washer/Dryer
Miele T 1515 electric dryer
Blower fan has fluff on stuck to it. It may even be disstorted. If you are really unlucky then it's done the blower fan motor bearings as well.
Dec 03, 2007 | Miele Novotronic T220 Electric Dryer
Miele Professional PT7136 Little Giant Stainless Steel Laundry Dryer Stackable, 15Lb 6.5Kg 34Gal 4.6CF Honeycomb Drum, Hot/Cool Air, Moisture Control Logo
94 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
