Question about ASUS Intel 815E Chipset CUSL2-M Motherboard
After swith on my CPU it take 40 min to on my computer
After swithcing on my computer, only Processor fan and SPM fan starts running, It take aroung 40-50 min to start my computer( i.e to start the harddisc, to start monitor and to start my CDROM)
  • ahhussain Jan 13, 2009
    Thanks for promt reply. I took out my mother board and CPU also. I cleaned everything. Again i reassemble all the configuration. Still problem exist. Is there any problem with mother board or processor or RAM?
Well try taking ur motherboard out cuz it may be shorting on something or ur cpu mite be on its way out so just make sure u check that
Posted on Jan 13, 2009
How to upplug fan in desktop
How to Reduce the Noise of Your CPU Fan
The CPU fan is what keeps the processor of your computer cool while the machine is running. A noisy fan on the CPU can be very annoying for users of the computer. However, it can also be a sign of a dangerous problem in your system. If the CPU fan is making noise, it is probably not running at full capacity to cool the processor, which leaves your computer open to problems involving overheating of the processor. An overheated processor can be permanently damaged.
Step 1
Unplug the computer from the wall. Remove all devices from the back of the computer and move them away from the area where you will be working. Either wear an anti-static wristband or discharge any static by touching a metal part of the computer case.
Step 2
Remove the screws from the back of the computer case with a screwdriver. Pull the sides of the case off and set them aside. Lay the computer on its side so that you can easily see the motherboard and all parts connected to it. Locate the CPU fan; it will look similar to the image in the introduction.
Step 3
Ensure that no cables are hanging low and touching the blades of the CPU fan. Move any cables or other parts that could be hitting the blades of the fan causing noise. Tuck these cables and wires into an area where they cannot interfere with the CPU fan.
Step 4
Use a cotton swab to remove any dust that you can from the blades of the CPU fan. Don't use any harsh solvents or other cleaners that could drip down and damage the processor through the fan.
Step 5
Spray the compressed air into the fan to move the loose dust away from the processor fan. Move the dust into an empty section of the case with the canned air. Don't spray the air too hard or else you can spread the dust into other places in the computer.
Step 6
Use the vacuum cleaner to vacuum up the dust that you moved away from the CPU. Place a crevice tool or other attachment onto the hose to reduce the size of the opening and help ensure that you only remove dust.
Step 7
Replace the computer case. Plug the computer and all devices back in. Boot up the computer and check for reduced CPU fan noise.
Oct 31, 2012 | HP Computers & Internet
Computer shuts off after 2 mins when case side panel is on
Might be faulty PSU power supply unit
it sounds like a loose connection of some type check the power button connections make sure the soldered wire connections are good and dust free
check cmos battery seating some motherboards cmos batteries are soldered in
it could be a loose or faulty power or data lead check these from motherboard to hard drive also make sure the CPU cental processing unit has a secure dust free seating an has thermal paste
it does sound odd
hope this helps
Jul 04, 2012 | Computers & Internet
I have a Compaq Presario PC, SR5210NX Processor with Intel Celeron Processor 420. I got a message that windows did not start correctly and it said to run the diagnostic, which I did. After that was done,...
Unplug power and Open the computer case. Vacuum all the dust
inside it. Visually inspect all the fans: Power Supply, CPU, Chipset
and Case...Make sure they are spinning easily and freely.
Plug the power in, and turn on your system. Watch the fans, especially
the CPU Fan and the Main Board Fan (System Fan). Oil and dust over
times may accumulate and prevent the fans from spinning properly.
If you are handy, you can remove them, give them a good wash and lubricate
the shafts with a few drops of WD-40, they will be as good as new again.
Fans don't go bad that easily.
Jul 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
My laptop swithces off itself every 40 minutes
This is typical of a overheating (thermal shut down) CPU problem.
When the CPU overheats and shuts down, it won't bootup again until the CPU cools down. If this is not fixed then the CPU will fail.
This problem is caused by either a faulty fan or the fan and heat assembly is clogged with dust.
Check the fan to see if it spins freely, replace if faulty and clean the dust off the fan and heatsink assembly.
Also apply fresh thermal paste to the heatsink/CPU.
Sep 29, 2009 | CMB T43 750 Notebook
The cpu fan wont run--i cleaned it with air can--if i hold the start button down it will stay running but make a lot of noise--when i let up on the switch it will die--i think the cpu fan burnt out causing...
Try replacing the fan first, and see if the computer starts, and runs normally, otherwise you could have fried the CPU. In that case a new processor is needed.
Aug 04, 2009 | ASUS Computers & Internet
My CPU fan for my Dell Dimension 2350 has stopped turning!
If your fan is not turning at all then it is probably dead, the bearings are likely clogged with dust and such. The PC is shutting off because of heat buildup on the processor chip. You need to do an Ebay search for your model and order a fan right away. Continued running of your sysem without a fan will kill the processor and motherboard. You should be able to get a replacement fan for your computer for less than $15 including shipping. Your local computer store may have one to fit your system but they may charge more for it. To change the fan is very easy, the left side of the case will come off your system, right under the power supply is the processor and heatsink and the fan. Disconnect the old fan and reconnect the new unit.
I hope this helps, if so please rate my solution
Buddy
Corporate Computer
WWW.CCL-LA.COM
Jul 02, 2009 | Dell Dimension 2350 PC Desktop
Computer turns on but no Video and doesn't go through POST.
Before you "fry it" try taking the CPU fan off of the processor, remove the processor, reinsert the processor and CPU fan and see what happens.
Nov 11, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Computer Shuts down
Well your processor may be damaged..
dont worry may be it is not damaged so what do you do is that open the cover of your computer.... Then start it and keep the cover opened making sure that you can see the processor fan running...
See that if the processor fan is running...
then with the help of a torch see that may be the fan is being restricted or it is moving slowly.
this slowness of the fan heats up the processor and makes it shut down you PC
if the is running slowly take out the fan using the user guide of the processor and then lubricate it with motor oil.
it IT Does not work then there is a problem with your processor so please check by placeing another supportive processor and check it!
Dec 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor over heating
This is normal behavior. Fans normally only run when they are needed, and your computer has multiple temperature sensors that direct this behavior (they are primarily located on the CPU, which could explain why the fans all worked when you took the CPU out). You should only be concerned about the fans stopping if your computer is, indeed, overheating.
Nov 14, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Processor overheating
Hi have you cleaned the heatsink? Also replace the paste on the CPU, also you could try installing an extra fan on the case to increase air flow. Also check that your RAM is seated properly and any other chip and card on your board is firmly plugged in. If all this fails replace your CPU. Regards mistyman
Sep 10, 2007 | Intel Pentium 4, 2.8 GHz (bx80546pg2800e)...
ASUS Intel 815E Chipset CUSL2-M Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
