Question about GE Profile Spacemaker Series : PNM1871SMSS 1.8 cu. ft. Over-the-RanMicrowave Oven
Need Help WIth GE Profile Microwave Active Vent Door
The microwave is above the stove and under a cabinet. The active vent door is located on top of the microwave. The vent door swings open when the fan operates and closes when the fan shuts off. There are two springs on the left and right side of the door that are attached to a plastic tab that allow the door to open about one half of an inch. One of the plastic tabs broke. I do not understand how to remove the vent door to replace the part that has the plastic tab.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: No sure how to remove oven from under cabinet in motor home
You can download GE owner's manuals and installation instructions here.
If you need further help, reply back with your model number.
Posted on Dec 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Posted on Jan 11, 2009
garing
  • 998 Answers
SOURCE: I took the cover off my GE profile microwave and
look where it is catching you will find it keep trying....i had a bag of a time too just relax go slow... lite.. helps(bud lite)get someone to help balance it and thumbs up
Posted on Aug 14, 2009
SOURCE: Venting of microwave - house stinks of bacon
Interesting post, because I have the same problem! I have spent the better part of today researching and taking our microwave apart (partially) to inspect the top portion re: outside vent. Everytime the microwave is on, the "active vent door" (manufacturer's term, not mine!) opens. Apparently this is normal. But it also opens when you turn on the vent fan, when cooking on the stovetop. I don't like this feature, because I think it 'overrides' the outside venting system. I double checked our outside vent to ensure that when this oven was installed, the person did in fact allow the flap to be open when the fan is on (he did). So I think what 'our' problem is, is that the microwave active vent sort of interferes with the outside vent, thus more of the cooking smell being blown into the house instead of the outdoors. I was thinking of simply disconnecting the gizmo that make the active vent door open each time you use the oven and/or vent fan option however I don't think that's a good idea as apparently the main purpose of the active vent door is to keep the electronics of the microwave oven from overheating. The more I read about this version of microwave, the less impressed I am with it. Lots of electronic issues with it. I am not fussy either with having the microwave over the cooktop. Sorry I don't have a solution for your problem but I do feel your pain!!!
Posted on Apr 11, 2010
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Mar 21, 2010 | GE Microwave Ovens
Can this microwave be vented to the outside?
Yes, this microwave will vent either out through the top or the back. A damper will be needed if it was not saved when the unit was installed. A list of other items are listed in the installation instructions at this link To GE.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 12, 2008 | GE JVM1860 Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Partial venting
Are you running the vent fan whenever you cook on the stove top? You should.
And you should run it on high if you're having steam problems.
Otherwise, you'll need to do something like use a small counter top fan to help circulate the air better.
Please let us know if we can help further.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Series : PNM1871SMSS 1.8 cu. ft. Over-the-RanMicrowave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
