Wh45x10070 basket trunion only
Would like to get trunion only for GE front load washer. Model #: WBVH6240FWW
fanny
  • 146 Answers
SOURCE: G.E front load washer Mo# wbvh6240fww
The door interlock may be faulty. Try closing the door firmly or hit the door handle when the door is closed.
Posted on Oct 31, 2007
the dr
  • 447 Answers
SOURCE: GE front loading washer - WBVH6240FWW
Most modern front loading machines have a ESTIMATED time display, this time can change based on the inputs from different sensors and water temperature. So this should be normal.
Posted on Jan 16, 2008
  • 240 Answers
SOURCE: ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Posted on Apr 27, 2009
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
heatman101
  • 43501 Answers
SOURCE: my GE WBVH6240FWW front load washing machine won't
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 25, 2010
Broken basket bracket- WBVH6240FWW
Please elaborate on this basket, is this a dish-washing machine?.
Jan 15, 2013 | GE WBVH6240F Front Load Washer
WBVH6240FWW GE FRONT LOAD control counts dow to 9 mins then jumps back to 11 mins in rinse and drain. I replaced the control. What else could cause this problem
Too much soap generally causes it to change time. Soap causes motor overload. The control detect over amping and declares a suds error. All machines have this built in though many do not display the error. Items between baskets can also trigger this.
WBVH6240 service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 04, 2011 | GE WBVH6240F Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Sep 27, 2009 | GE WBVH6240F Front Load Washer
My GE WBVH6240FWW front load washing machine won't spin.
heatman101
Jul 01, 2009 | GE WBVH6240F Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Ge washer
Apr 22, 2009 | GE WBVH6240F Front Load Washer
Oct 30, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
