Question about LG 42PQ30 42 in. Plasma TV
Lg 42pq30 is on but no imagen only one noise - LG 42PQ30 42 in. Plasma TV
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
I have an lg 42pq30 plasma tv the main input board went bad causing no audio.. i replaced the board with same part number .. it now has sound but the picture at the right is off the screen good 20% of...
You must use a usb memory stick to copy data values from the old board to the new board. First you have to put the old board back in, insert the stick then follow prompts to copy register values to the memory stick. Then put the new one back in and load the values back onto the new. I would definitely have a certified tech do this process. You don't want to make a mistake with the old board values.
Feb 18, 2011 | LG 42PQ30 42 in. Plasma TV
I have an lg 42pq30 the main input board lost sound so i replaced it with same part number.. got sound back but the video runs off the right side of screen...any help thanks in advance
you need the set up remote, part number 105-301-m . in start mode press tools button, rt click until your model shows up. the main board is for several size screens. HIT enter when you see your model number.
Please post feedback
I have a problem with my lg 42pq30 plasma, it has vertical lines distortion across the screen. does anyone know how to fix this problem
yes is the 2 top & botton board connect to Y board control is bad need new one
Most problem on plasma TV is heat & burner some component, about 80% is 2 top & bottom board connect to Y board is come in bad
Feb 04, 2011 | LG 42PQ30 42 in. Plasma TV
Plasma Television won't turn on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Jul 02, 2010 | LG 42PQ30 42 in. Plasma TV
How do I get LG Plasma TV 42PQ30 to work with a dell laptop in connection use of a VGA/SVGA video cable. Thw hook up should act as a plug and play if my understanding is correct. I am using the RGB IN(PC)...
well, if the cable and adapters are friendly (meaning, you are able to plug the right video connection from LT to TV), sometimes you need to tell you LT that you have a second screen to output video. To do that, there should be a display icon in your bottom-right taskbar. Double click, and you should be able to see the options to either clone, pan, or primary your second display screen. :D
Mar 21, 2010 | LG 42PQ30 42 in. Plasma TV
Lg plasm flat panel tv 42pq30 one month old has vertical pink and green lines that roll from bottom to top any answers.
Your set should be under warranty. This could be a clocking circuit that is out of sync, or some other processing device that is out of frame sync. To service this at board level, if it is not a standard factory known fault to correct, or if it involves extensive SMD work, the board with the fault will be replaced.
Jerry G.
Jan 23, 2010 | LG 42PQ30 42 in. Plasma TV
Need owner's manual for LG 42
You can get the manual on link below. Go to support then look under documents on right side to download manual.
http://www.lge.com/us/tv-audio-video/televisions/LG-plasma-tv-42PQ30.jsp
Nov 25, 2009 | LG 42PQ30 42 in. Plasma TV
Lg 42'' plasma 720p no picture
This is not good. Was your tv unplugged or just power button off when you left for vacation. PlasmaTvs are highly susceptible to damage from power surges caused by lighting. Leave unplugged for at least five minutes then plug back in and see if this helps.
Aug 15, 2009 | LG 42PQ30 42 in. Plasma TV
LG 42PQ30 42 in. Plasma TV Logo
32 people viewed this question
Computer Repairing
Computer Repairing
