Question about Kenmore Microwave Ovens
My microwave oven quit heating . No error message or any other problem. all buttons work fine just no heat
    Top Expert:
  • 14,553 Answers
If it has a turntable that does move it usually means one of three things bad:
1. A diode many use for power purposes for the heating.
2. A circuit board called an inverter that powers the heating and controls the Magnetron.
3. A Magnetron which does the actual heating.
my microwave oven quit heating . No error message  - 12_11_2012_3_08_28_pm.jpgTypical diode which cannot read shorted or open across.
12_11_2012_3_10_09_pm.jpgTypical Magnetron which usually cannot be tested by normal means but has to be replaced to know if good or bad.
Posted on Dec 11, 2012
5 Suggested Answers
biigg53566
  • 89 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Posted on Apr 17, 2009
  • 97 Answers
SOURCE: MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Posted on Jun 10, 2009
  • 327 Answers
SOURCE: 66993 pizza oven microwave oven combo
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Posted on Jul 13, 2010
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
It has been working fine & suddenly seems louder and is not heating.
When a micro wave quits heating there can be a number of different issues that could cause it not to heat. Because of the way a microwave works it is best to have it checked out by a professional that knows how to handle the high voltages that can be present inside a microwave oven.
Here is a tip that I wrote about troubleshooting microwave ovens and explains things in more detail.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 28, 2010 | Samsung SMH7174BC Microwave Oven
My LG Microwave (LRM1250W) does not heat all of a sudden
Basic Microwave Oven TroubleshootingTips
heatman101[p]][p
Feb 17, 2010 | LG LRM1230W Microwave Oven
Our microwave oven started making a loud sound and quit heating
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
My GE spacemaker xl1400 microwave quit heating. worked fine, timers, clocks and everything else is fine
heatman101
lkkg
Nov 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Sunbeam microwave doesnt work
i just brought my sunbeam microwave like two days ago. and it will not heat up
Jan 22, 2008 | Sunbeam SMW777 Microwave Oven
Microwave will not heat
If all controls on the panel work fine but the microwave does not heat, then either you have a defective door switch,the smartboard is defective, or you have a defective magnatron.Most likely one of those three.
Nov 06, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
979 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
