Question about Aviton 4.3 Inch LCD GPS Portable Navigation System
Aviton x13-12058 not working can not set the gps
Why no gps works with proscan tablette
Does the manual say you have a GPS chip on that tablet? Is the GPS enabled in Settings? Is the GPS application stated to work with your tablet? Without more details, it is not possible to help you out much further.
Aug 04, 2014 | Proscan 8" Tablet with 4GB Memory
The gps on my htc sensation 4g doesn't work
First, make sure that your GPS issue is not a settings issue. Try going to settings > Location & Security > Make sure "Use GPS satellites" is checked.
If that does not fix your issue, restart the phone, retry the above process and try it again.
If all else fails, your GPS module and/or software is broken or corrupted. Contact your service provider for a warranty replacement.
Jun 18, 2012 | HTC Sensation 4G
Waiting for GPS comes up when I try to get directions, it never loads
what are you using for gps? ovi maps? garmin? google maps?
i suggest installing google maps to see if your gps is working alright.
then check in phone settings to ensure that gps positioning method is enabled for 'built-in gps' and 'assisted gps', thereafter check positioning server is set to 'supl.nokia.com'.
normal lock time is around 5-30seconds with E71 GPS with A-GPS on; anything more than that i'd attribute it to a faulty built-in gps unit.
let me know if it works.
Jan 26, 2011 | Nokia E71 Smartphone
Humminbird Matrix 12 sonar/gps problems
Make sure the 'North Up' is set to 'True' in the settings.
Best of luck
Mike
May 03, 2009 | Hummingbird Humminbird 1155C GPS Receiver
I cant find my gps on my samsung omnia
I have a Samsung Omnia. If you go into settings you can turn on AGPS (assisted GPS) and download some addition software that helps gps. GPS is automatic but you can turn it off or allow windows mobile to manage it which is advisable. You cannot automatically see the GPS but you can buy or get third party software to see when GPS is working.
GPS gate works to turn gps on/off manual but this is just one software.
I have included a link to show where these settings are and if you want to use GPS gate. Note: I am not affiliate with GPS gate at all.
Nov 13, 2008 | Cell Phones
GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Jul 14, 2008 | Apple iPhone 3G
My HTC TyTN II GPS does not appear to work. I have bought the device, and when I first installed TomTom the device was able to get a GPS fix, Howeve after I ran external GPS, the device no longer seems...
I Got it!
I finally got my HTC TyTN II yesterday from Dubai.
First thing I wanted to test was the GPS. It did not work with: TomTom6, Google Maps, Yahoo Go.)
I was surfing around to find something that would help me out and have noticed that many people have the same problem.
Many people (Like me) did not know howe to setup the GPS.
Many people are saying: "You have to put it your GPS settings in Com 4 and the Baud rate on 4800 and it should work.
Well mine didn't work with those settings. (Along with other people.)
I had played with the External GPS option (Don't do this cause setting something wrongm ay cost you a HARD-Reset.)
I Was lucky that mine worked again after a SOFT-Reset. So watch out!
The standard GPS settings! (If you have changed it, Soft-reset your phone and set it up as these pictures show.)
Why am I doing this?
People buy this phone to make use of it. When something does not work why buy the phone then :S
Hope that this may help a lot of people on here and other forums, communitys & websites.
Here is my story of how I did get my GPS to work:
1. Download the GPS addresses by using QuickGPS (Start -> Programs -> QuickGPS).
(This will download info of what your GPS Reciver needs to connect to the satalites.)
2. Download a free (Well half free, You can also buy this application it will give you some extra options, but we don't need those extra options.) tool named: GPS Test. (http://www.smartphone.net/software_detail.asp?id=3170 or at http://www.pocketpc-software-downloads.com/software/t-free-pocketpc-gps-test-download-uykfcoyy.html)
(This program will scan all your mobiles com ports and Baud rates, To see what your real GPS settings are.
In my case they were: COM PORT: 4 - Baud Rate: 9600 (Notice it ain't 4800. Usaly it shows your settings with a pop-up.
When It doesn't Go to "Menu -> GPS Settings", There it will show you you're GPS settings.)
3. Install TomTom 64. Download your free map.
5. Go to the GPS settings.
(Set-up: Other NMEA GPS-Reciver -> GPS-Baud Rate -> Com. (Select the Baud rate + Com port from what the GPS Test did show you.)
6. Now wait.
Jun 29, 2008 | GPS
After instaling the 2008 map update in my Garmin c330 GPS my GPS is not working anymore.
I found the answer in Google. The answer is: shut off the GPS. Then press and hold the right hand corner of the screen. Then press and hold the on and off switch of the GPS, till a white screen appears and follow the instructions on the screen. This will set the GPS back to the factory settings. It worked like a charm.
Jun 22, 2008 | GPS
No GPS signal?
I had this problem (waiting for a valid GPS signal). I did a factory reset and the unit started working again (yes, I lost all my settings, but what good is a GPS unit that just sits there waiting for a valid GPS signal?). To do a factory reset, go to menu -> change preferences -> Reset factory settings.
Jan 17, 2008 | Tomtom ONE GPS Receiver
Aviton 4.3 Inch LCD GPS Portable Navigation System Logo
61 people viewed this question
Top Aviton GPS Experts
Will Halftowaite
Are you an Aviton GPS Expert? Answer questions, earn points and help others
